Question about Saeco Coffee Makers & Espresso Machines
My Saeco Odea Go is leaking water through the wand while coffee is being brewed.I expect it is a seal, how do I take apart and replace?
SOURCE:
SOURCE: Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Posted on Nov 07, 2007
mirran
  • 515 Answers
SOURCE: brew group on saeco odea giro wont go back into machine
try to put in the dregbox to the machine, close the door and power on the machine. When the machine not make any noise, open the door and put in the brew group.
Posted on Aug 02, 2008
  • 3 Answers
SOURCE: saeco odea steamer is leaking
This is a known issue with the Odea GO. You need to take it in for servicing to get the rubber seals changed. This happened with our maching after about 6 months.
Posted on Mar 09, 2009
  • 81 Answers
SOURCE: Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Posted on Feb 03, 2010
  • 81 Answers
SOURCE: I have a new Saeco Odea Giro Coffee Machine and
Is it the red light flashing and the water button light also on? That means air in the system.If the flow of water is not steady, make sure water tank is fully push in.
The next thing you can check is the test mode which is not given in the manual.Hold down water button and switch on the machine,you will see the lights turning on alternately in anti clockwise direction. Release the button.Turn the dial to the right and press the coffee button, water pump will work.Turn on the steam/water knob and keep pressing the coffee button until all the air is purge out. Dial on other positions will test other components of the machine,such as grinder, solenoid valve , brew group,etc: I hope you can solve your problem with this information.
Posted on Feb 22, 2010
Exclamation point flashing
For Saeco Odea Go Team De-Brewerz.com says:
1. Your coffee maker might suffer from Steam, Coffee Bolier clogging due to scale. Due to clogging you are unable to product perfect steam, temperature drop in coffee, inconsistent steam flow, inconsistent water flow etc. We strongly advise you to do regular Descaling to your coffee maker (every 200-300 cups or 2 months)
2. If your coffee maker in working condition but still light is keep on blinking means required "Descaling". Please use the food graded Delonghi or equivalent brand descaler.
3. Remove the brew unit from the machine. Check the mechanism and refit the same into the machine.
You can order to us @ www.De-Brewerz.com or buy online in India @ www.fabkaart.com
Still issue not resolved claim the warranty if recently purchased. If you are in India then contact us @ www.De-Brewerz.com
Nov 03, 2014 | Saeco Odea Go
I have a Saeco Giro that leaks coffee under the machine
check the brew unit .there is something wrong with "O" rings
Oct 07, 2014 | Saeco Odea-Giro Espresso Machine
Coffee just trickles out, only about two tablespoons of liquid comes out during the whole coffee brewing cylce. I have descaled unit twice to no avail. Water does come out of the water wand ok.
There are 2 things that might be going on;
1 - The brew unit screen is blocked.
2 - The grind you are using is too fine, try adjusting to something a little coarser.
May 16, 2011 | Saeco Odea Giro Plus Coffee Maker
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Hi, I have a saeco odea giro plus that has just started to leak nearly all of the brewed coffee into the dreg drawer! Any ideas? thanks in advance...
I had a crack in the tube that connected to the brew group that resulted in a similar dumping of coffee in the dregs (and below the dreg drawer and onto the counter) in my Saeco Odea Giro. Replacing the "Saeco Odea Giro Coffee Dispensing Tube, part number 11003468, fixed my problem. You can replace this yourself if you are very handy. These photos are very helpful (The Go seems pretty similar to the Giro.) http://odeago.zxq.net/Odea_Go_Repair/Welcome.html
Aug 04, 2010 | Saeco Odea Giro Plus Coffee Maker
Water leaks from the bottom of the odea go when brewing. We have soaked the brew group, tried to lube every spot we could think of, and still no luck. Machine is 1 and 1/2 years old. thanks.
If it's from the left side of the machine, probably the tap valve seals are leaking. If alot of water leak out without any coffee from the spout, then the hoses rupture or boiler leakage inside the machine.
Jun 18, 2010 | Saeco Odea Go
Feb 03, 2010 | Saeco Odea Go
Water dripping of Steam Wand during brew cycle
If water is dripping out of steamwand then the valve assembly is not working properly and needs to be replaced.
Aug 17, 2009 | Saeco Odea-Giro Espresso Machine
Frothing valve leaks water when not in use
There are 2 inserts pins in the steamvalve assembly, they need to be replaced replace. Easiest solution order a new valve assembly.
Feb 23, 2009 | Saeco Odea Giro Plus Coffee Maker
Saeco odea steamer is leaking
May 10, 2008 | Saeco Odea Go
Coffee Makers & Espresso Machines Logo
79 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
