Question about Emerson Televison & Video
My Emerson TV model LC320fm1f Won't Turn On But red light stays on when I plug it in
SOURCE: EMERSON EWL3706 37 IN. WONT STAY ON
had same problenm with mine it was a fuse that blew. took repairman 5 minutes to fix charged $136.00
Posted on Apr 29, 2008
SOURCE: Lg tv will not turn on, red light
i think your bulb is shot must be replaced
SOURCE: my emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Posted on Dec 20, 2010
  • 184 Answers
SOURCE: Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Posted on Aug 01, 2011
  • 1039 Answers
SOURCE: My tv won't turn on. There is a red light
Replaced any capacitors on the power board that have domed tops.
Posted on Sep 01, 2011
I have a 27inch Philips flat TV that when its pluged in the light is solid red and TV won 't turn on
Common TV Repair for Emerson, Sylvania, Philips, Magnavox
? 5:35
www.youtube.com/watch?v=nQHWrJJg4Mc
Oct 11, 2013 - Uploaded by Tampatec
Top most common LCD TV repairs for Emerson, Sylvania,Philips, ... my tv wont turn on neither the led ...
Nov 01, 2015 | Philips Televison & Video
My emerson lc320em1f tv won't turn on.
Calm down, Calm down! Your power supply board is at fault. On the power supply, you have a bad diode. Location of this diode is D639. Replace it with an NTE 5087A. Thanks for asking, Matt of Martins TV Repair.
Jan 27, 2013 | Televison & Video
Emerson tv....won't turn on...stand by light won't go off
Not making it on or out of standby---first place to look is the power supply for signs of damage or puffed up filter caps there.
Dec 10, 2012 | Emerson SLC195EM8 LCD TV
It won't turn on, the red light flashes
That means that its no good and needs to be replaced
Aug 02, 2012 | Emerson LC320EM8 32 in. LCD TV
I have a Emerson 32inch LHD32K20US and it won't
ry changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | Televison & Video
I need code for tv
Hello
Three digit universal remote code for emerson are:-
004/ 009/ 014/ 023/ 024/ 025/ 026/ 027/ 030/ 032/ 033/ 034/ 035/ 036/ 037/ 038/ 039/ 040/ 041/ 042/ 043/ 045/ 046/ 049/ 053/ 116/ 135/ 147/ 177/ 179
Four digit universal remote code for Emerson TV/vcr combo are:-
0456 [0458 0227]
Where the code is listed as [### ###] the first is for the DVD and the second is for the VCR. Otherwise just the one code operates both the DVD and the VCR
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Also try these four digit codes for Emerson Tv also. There are so many codes for Emerson Tv.
0004 0009 0044 0135 0049 0051 0189 0053 0147 0039 0130 0227 0233 0250 0252 0254 0257 0265 0266 0310 0325 0456 0040 0041 0042 0021 0023 0024 0179 0045 0025 0027 0030 0032 0034 0035 0037
Nov 26, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
My emerson TV will not even turn on. Took a nap with it on, woke up it was off. Everything else on the surge protector still works, tried plugging it into another outlet, but still nothing...
sounds like you blew the lcd or plasma, I did the same with my Vizio, hopefully you do not have the same problem.,, does the power light stay on and no picture, and if so try and turn the power button off, if it does not shut off, and you unplug it and it shuts off and the red light goes out, and then when turn it back on the red light is out until you turn it on and the same thing happens all over again
Jun 13, 2009 | Emerson LC320EM9 32 in. LCD HDTV
My emerson tv standby light is on the power light flashes twice
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
I have a emerson 32 in.
fuse is blown cost about 100 to 150 to fix
Aug 07, 2008 | Emerson EWL3706 37 in. LCD Television
Televison & Video Logo
23 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
