Question about Microsoft Windows XP Home Edition
Can't get yahoo messenger to download on my pc,tried everything,firewalls down ,pop ups off what else help?
I want my yahoo messenger,thank you.
  • 383 Answers
Re: can't get yahoo messenger to download on my pc,tried...
Restart your computer and being again , go to www. and redown load again if u have windows 95 you will not get yahoo messenger.Need a up date computer.
Posted on Nov 26, 2007
0 characters
3 Points
Yahoo messenger is not installing
check your firewall settings or if you have antivirus software that might be stopping the installation of yahoo messenger. try to download again the yahoo messenger. check you might already have installed it and might have corrupted the installation. check the program files folder if you can find the yahoo messenger folder then delete that or check add and remove in control panel if you can uninstall the yahoo messenger that you previously installed.
Apr 22, 2011 | Operating Systems
I cant download yahoo messenger it say that has to do with my firewall i've turn off firewall but still cant download messenger
Do not turn off firewall it will not allow to install the messenger.
Turn on firewall and restart your computer and reconnect with internet and try to download messenger.
If you are not downloading messenger from legal or untrusted website then it is familiar to do that for computer.
Apr 09, 2010 | Microsoft Windows XP Professional With...
M having windows vista yahoo messenger 8.1 is not intalling
Right Click in Yahoo Messenger ,exe And go to Trobulshuting Complier
Plz Install
Aug 17, 2009 | Microsoft Windows Vista Home Premium...
How can i download yahoo massenger
Download the Yahoo Messenger directly from the link :-
Once downloaded, Double click the icon that you would save on your desktop.Once installed, restart the PC and it's all set.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 07, 2009 | Microsoft Operating Systems
Cannot make a full connection to yahoo messanger it shuts down.
First please uninstall the yahoo and install the latest version of yahoo messenger from net. Next please follow the step by step troubleshooting if you are still facing the issue:
Instructions Step 1:Reduce echoes by using a headset instead of speakers and a microphone. Place the microphone farther away from the speakers, if possible. Adjust the volume of the speakers and the microphone.
Step 2:Verify your Internet connection speed if your friend's voice sounds choppy. The computer modem speed must be 56K or higher in order to send voices or sounds.
Step 3:Go to "Actions" and "Call Setup" in Yahoo! Messenger if you can't hear, or your friend can't hear you. Test the sound by following the instructions that proceed call setup.
Step 4:Click on the speaker icon in the lower right corner of your computer screen if you want to test the sound manually. Uncheck "Mute," if necessary, and make sure sound levels are above 50 percent.
Step 5:Pick "Preferences" in Yahoo! Messenger if you have trouble with connecting to the voice server. Choose "Connection," then select "No Proxies." Log in to Messenger again to check the voice server.
Tips & Warnings Follow your computer system's instructions for checking or modifying the server's TCP ports. Ports numbered 5050, 443 or 80 must be open for the voice features to work.
Install the audio codec software that comes with Windows. PC calls and voice chat require that the software is enabled on your computer.
Thanks for contacting Fixya.
Jun 22, 2009 | Microsoft Windows XP Professional
Error code81003004
Messenger 9 for Vista users and XP users with 9, The updated Windows Firewall will not let Messenger download correctly.And is causing 9 and 8.1 users to have problems now.. The only option that might help is turning off the firewall to download and install then turning it back on.Go to control panel, click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.0 or 7.5 these and all versions of messenger can be found here;
You need to remove version 9 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
Jan 25, 2009 | Microsoft Windows XP Home Edition
Connection problem 81003004
To solve this kind of network connection in your yahoo messenger, just click on your yahoo messenger, select the connection preferences in the menu and then select the proxy server as the connection preference other than the internet one. then select from either the dial-up, broadband or the high speed t1 lan connection. it's up to you how you connect.
it works for me. hope this can help you.
Jan 19, 2009 | Microsoft Windows XP Professional
About yahoo messenger
Yahoo! has problems quite abit with everything they have e-mail, .com site and especially there messenger I would recommend you try uninstalling Yahoo! Messenger then re-installing yahoo! messenger then try again. let me know how this works out
Thanks !!!!
Oct 05, 2008 | Microsoft Windows XP Professional for PC
I cannot install yahoo messenger
do firewal setting
if you do not knew
click start
type firewall
click firwall there then click advance setting
there trun off download it
Aug 13, 2008 | Microsoft Windows XP Professional
Yahoo Messenger, BUZZ, WORM?
have you tried booting to safe mode ?
Feb 11, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows XP Home Edition Logo
109 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
