Question about Toshiba Satellite 2060CDS Notebook
Winlogon.exe entry point Library OLE32.Dll /string from GUID 2
Can not get the programs to run
  • 1,601 Answers
Re: winlogon.exe entry point Library OLE32.Dll /string...
0 characters
3 Points
I recently did a repair on windows xp and was wondering did everything go well? Here is my report: Logfile of Trend Micro HijackThis v2.0.2 Scan saved at 6:22:26 PM, on 3/23/2010 Platform: Windows XP SP3...
Apart the fact you have way too many programs on autostart, that there are still traces of the infection left and you are running a pirated OS, no.
Mar 24, 2010 | Acer Aspire 3000 Notebook
How to customize your start button
First you need a tool called "Resource Hacker". This free program allows you to change resources in any .exe file such as "Explorer.exe", which includes the [Start] button's Label. You can visit and search there for "Resource Hacker".
After you download it, follow the guide here:
Step 1:
A - Run "Resource Hacker" and open the file "%windir%\Explorer.exe".
B - You see a Tree of all Resources in this file, expand the "String Table"
C - Find the "start" and replace it with your own text. then press the [Compile Script] button.
D - Save "Explorer.exe" as "MyStart.exe" DONT save it as Explorer.exe, do "save as.." and give it a new name.
E - Quit "Resource Hacker".
Step 2:
A - Click on the [Start] button and choose the "Run..." item from the start menu. (Or use the shortcut key WinKey+R)
B - Type "RegEdit" in the Run "Dialog Box". And then press the [Ok] buton to run the "Registry Editor" program.
C - Go to: "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogon" and find the "Shell" property.
D - Replace value of the "Shell" property to "MyStart.exe".
E - Quit "Registry Editor".
F - Restart your system.
Note about Registry Editor:
if you did not find the key "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\Winlogon", you can search the Registry for the "Explorer.exe", to do this use the Edit Menu | Find Next (Ctrl+F).
AmirBehzad Eslami's site has a handy tool for altering your start button, which makes life much easier, you can find his site here:
on Mar 06, 2010 | PC Laptops
Error message: procedure entry point PowerReadACValue could not
tvagente.exe is used to use computer as a TV. If you do not use it, you may want disable it. It uses excessive system and memory resources If you are not using the TV application, you should remove it to improve your overall system's performance. anyway try in run-msconfig-startup the entry for tvagent.exe and disable
Mar 06, 2010 | HP Pavilion dv9000z Notebook
TVAgent.exe - Entry Point Not Found The procedure entry point PowerReadACValue could not be located in teh dynamic linkk library POWRPROF.dll. how To fix it when i try to close out on the bx another...
TVAgent is a Cyberlink software for HP machines. It's used to use computer as a TV. If you do not use it, you may want disable it or uninstall it.
If you do use it, uninstall it and then download and install the new package for the HP MediaSmart TV it is SP42505 dated 3-2009
Nov 26, 2009 | HP Pavilion dv9000z Notebook
I have a hp dv7-1468nr and im getting this problem TVagent.exe the procedure entry point PowerReadAcValue could not be located in the dynamic link library POWRPROF.dll. Can some body please help me solve...
At the start button, choose run. Type MSCONFIG in the text box and hit enter. Choose selectice startup and go to the startup tab. On the startup program list, scroll down until you find an entry for TVagent, uncheck the program so it will not load immediately until it is needed. Click apply and ok to restart the system. You can also disable auto start for other programs as well.
Nov 14, 2009 | HP Pavilion dv9000z Notebook
Won't boot/reboot after turning off yesterday
1. boot from a Windows CD and go for the repair option.
2. Copy usp10.dll from c:\windows\servicepackfiles\i386\gdi32.dll to c:\windows\system32\usp10.dll. (Do keep a backup copy of the old usp10.dll in c:\windows\system32 directory )
3. Reboot normally
Jul 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Sony vaio won't boot tells me no entry point found. plz help
WINDOWSLogin or WINLogon?
The first is or must be part of something trying to load at boot time, the 2d is required to start windows. You can start in SAFE mode (Press F8 while booting) and test the first (Windowslogin.exe) - If it boots all the way into BASIC looking (no bells) Windows, the PROGRAM trying to load is the culprit. Next, restart in SAFE Mode with NETWORK Support, DL 'Malwarebytes' and let it fix it - or at least tell you if it is malware (I suspect it is)
You can start in Console Recovery mode (Boot PC from O/S CD and select recovery Console) and simply copy over a new WINLogon.exe from your system32\dllcache directory using the COPY command
Apr 08, 2009 | Sony VAIO FX250K PC Notebook
Internet explorer raised unhandled exception in third party module IE will not start and the below call stack pops up every time. BASE:16940000,001B:1699D18C WINUTIL5.DLL,...
hi there,
it seems u got a big problem with ie7,
this is what is get right : Internet Explorer Unhandled Exception
> Internet Explorer raised unhandled exception in third party module and
> should be closed. We are sorry for inconvinience.
> Extended Exception Information
> Module: urlmon.dll
> Version Info: UNICODE; v.4, 0, 2, 3
> Call Stack:
> BASE:7E1E0000,001B:7E21B5CE urlmon.dll
> BASE:7E1E0000,001B:7E1F3FD9 urlmon.dll
> BASE:7E1E0000,001B:7E2150F2 urlmon.dll
> BASE:7E1E0000,001B:7E203342 urlmon.dll
> BASE:7E1E0000,001B:7E1FCD5C urlmon.dll
> BASE:7E1E0000,001B:7E1FCD32 urlmon.dll
> BASE:7E1E0000,001B:7E1FCB8C urlmon.dll
> BASE:7E1E0000,001B:7E1FCB69 urlmon.dll
> BASE:7DC30000,001B:7DE84E02 mshtml.dll
> BASE:7DC30000,001B:7DD69D68 mshtml.dll
> Restart Internet Explorer Close
there is a simple solution for that just follow these steps and than all will go good
I would recommend resetting it to it's default state. This usually takes care of any problematic plug-ins. below has details on how to do this.
1. Click the Tools menu, and then select 'Internet Options.
2. Next, click on the Advanced tab to the far right and click Reset.
3. Another dialog box will then open up, click Reset.
4. Once IE7 is done restoring to the default settings, click Close and then OK.
5. Close any browsers you may have had open and restart it. Everything should now be reset to the default.
or for just click this link and than click on download and run ie7 new
Dec 18, 2008 | HP Pavilion dv6000z Notebook
Sprtcmd.exe-Error Point Not Found
You cannot are you able to reinstall the operating system have you tried to restore from safe mode.....?
Jul 14, 2008 | PC Laptops
Warning on boot: savedump.exe Entry Point Not Found"
Can you go into safe mode by pressing F8 after starting? If so go into device manager and remove any recently installed hardware. Also try to roll back to a previous point in time when the pc worked by going to start/programs/accessories/system/system restore.
Aug 26, 2007 | HP Business Notebook 6515b - AMD Turion 64...
Toshiba Satellite 2060CDS Notebook Logo
146 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
