Question about Toshiba 36A43 36" TV
No Picture on my Toshiba television
I have sound but the screen is black?
  • 232 Answers
Hi, those sets are pretty infamous for vertical problems, you probably need the IC replaced or you don`t have the B+ supply voltages getting to the IC, the only way to confirms this is to increase your screen control a little bit clockwise and if you see a bright white line running from L to R across the screen you will have confirmed that the vertical circuit has failed, NOTE, do not run the set for more than 10 seconds this way it WILL burn the picture tube. Hope this helps
Posted on Nov 27, 2007
  • 383 Answers
Try hooking the tv up to the back with the right cords. Turn off 1st and replug the tv and turn back on.
Posted on Nov 26, 2007
3 Suggested Answers
  • 476 Answers
SOURCE: Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Posted on Aug 03, 2009
Have the exact same TV and had the same thing happen a couple hours ago.
Posted on Apr 30, 2010
I have a Toshiba 50L2300U TV which has sound, but the screen is black. I believe it's because the backlight inverter is not functioning. What part needs to be replaced?
Hi Anonymous, The link below is a YouTube video showing how to fix a Toshiba television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
Toshiba 55HT1U repair No Picture
May 05, 2016 | Toshiba 50L2300U
Toshiba no picture
then your optical section has fault.
Mar 17, 2008 | Toshiba 61A61 61" Rear Projection...
Toshiba regza sound picture
It sounds that the back-light inverter bard has the fault. If you are somewhat sound in electronics, you can do the work by yourself. If you wish to get more details, check this link. It has troubleshooting details to many brand televisions, including Toshiba. Pull up older post there, either by its left side bar, or, see it in 'Timeslide' option.
Jun 21, 2013 | Televison & Video
No picture
try replaced DIGITAL PCB ***'Y
Manufacturer Toshiba
Part Number 72784100
Description DIGITAL PCB ***'Y
Apr 27, 2010 | Toshiba 50HP66 50 in. Plasma Television
I am repairing my sister TV {Toshiba TN61X81}. The original was no picture and with sound. Upon troubleshooting the vertical deflection, ihad move the screen control for all 3 crts to see the horinzontal...
The easiest way I have found to set the screen controls is to tune into an old black and white show, turn the green up until you see retrace then slowly turn it down until it just dissapears then adjust the blue and red for a true black and white picture.
Sep 08, 2009 | Toshiba TN61X81 61" Rear Projection...
Toshiba projection tv
Sounds like it blew an "Internal Fuse"
if you want to fix it..simply open rear of TV and look for the fuse.
here is link for a manual if you do not have one.
Feb 05, 2009 | Toshiba 43H70 43" Rear Projection...
2004 toshiba 65hx83 projection tv
How do you know when your light bulb has burned out? I have sound with a black screen
Aug 05, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba 46HM84 DLP Black and white pattern..
contact your dealer for service flashfor this symptom.(light tunnel)
Aug 11, 2007 | Toshiba 46H84 46" Rear Projection...
Black screen in middle of picture
go tothe menu, caption, take it off the text mode. this should solve your problem
Nov 13, 2006 | Toshiba 35A44 35" TV
Toshiba 36A43 36" TV Logo
205 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
