Question about Orion STV2763 27" TV
Help me fix my orion tv problem
I can't get my television to change my cable channels, if I press in 06 and then press the channel up button it skips 7,8, and go directly to 9, please tell me how to program this television to synchronize my cable channels, and it doesn't have a cable setting, it only have a ant, video1, and video2. Please help me.
  • lauren51783 Dec 06, 2007
    i have my cable wire in the tv and i can't get any channels
Cannot get my Orion STV 2763 to play video's from my Panasonic VCR (Model: PV 8661). Just got a hand me down (TV worked this morning) TV .
I must have hooked it up wrong. What are the necessary connections to get just these two to work properly?
Posted on May 21, 2008
    New Friend:
  • 53 Answers
Let it run an autoscan or see if in the menu it has channels that are blocked or disabled.
Posted on Nov 26, 2007
What's the imput button or code on remote for ten year old TV. Model #14MS2331/17
According to the manual for the Magnavox 14MS2331/17B, you switch to the A/V input by pressing Ch+ or Ch- on either the TV or the remote until you see AV as the current option. (Thus you have to scroll down from Channel 2 or up from Channel 69 for an OTA signal. For cable TV, the AV will be reached by Ch - from channel 1 or Ch + from channel 125.) See page 3 (7 of the PDF) here: .
Since it is possible to skip channels by editing the channel list, you may need to check if the AV option has been skipped. To do this, press Menu. Use the up/down buttons to navigate to Install and press the right button to enter this menu. Highlight the Channel Edit line and press the right button to check this. Once in this sub-menu, use the left/right buttons to scroll through the Channel number options (or use Ch+/Ch- to see the stored list). You can also type in a channel number on the remote. Press the down arrow to change to the line that reads Skipped. Use the left/right arrows to change between Yes or No. (No indicates you can reach the channel with the Ch+/Ch- buttons.) Use the Up arrow to return to the channel number line to scroll to other channels. Press Status/Exit to leave the menu system. See page 10 (14 of the PDF) for details.
I hope this helps.
Aug 28, 2017 | Televison & Video
Skip channel function not working coreectly
db:: 4.90::Fios tv VMS1100 skip not working correctly k3
DB:4.90:Fios Tv Vms1100 Skip Not Working Correctly k3 ... Pressing Play on the remote has no effect, but changing the channel fixes everything. ..... The functions Skip Forward, Skip Backwards, Next Chapter and Previous Chapter all skip ...
The Secret Method to Skip Commercials with One Button on ...
Dec 28, 2015 | Televison & Video
I lost the remote to my Toshiba cz27t31. I bought an RCA universal remote. The RCA manual says the tv should be set to channel 1. But I can't change the channel without the remote. So I am SOL! How...
  • You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
  1. Press "MENU" on the TV until "SET UP" appears on the screen.
  2. Now press ^ or v until "FAVORITE CH" appears in purple.
  3. Now press < or > to display the favorite channel FAVORITE CH menu.
  4. You will use < or > to got between "SET and "CLEAR."
  5. So now go to "SET" and press ^ or v until you get to channel 1.
  6. If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
  • What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Toshiba CZ27T31 27" TV
We have an orion model 1934 tv and can only pick up a few channels on it-less than 12 and it is hooked to our cable which has 70 channels access. this is a 2002 year make so i think it should pick up a lot...
If you can, go into the ch set menu and change it from tv to catv(cable). then run the auto ch memory. I hope this helps. Orion's free help line is 800 289 0980.
Dec 17, 2008 | Orion1934 19" TV
#4 & #5 buttons do not work on my remote. Channel 55 wont come in either on my tv
I had that problem 2 my channels disapeared one by one and some will skip yes...
I always use on my remote controll :
1 menu
2 Ch tuning
3 auto
and then wait untill it has found all the channels
Oct 02, 2008 | Orion1934 19" TV
Program channels
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Symphonic television
Use the original remote, or the menu button on the tv. Press menu. Find "setup" or "channels" or the word cable or autoprogram. Choose cable. Then choose autoprogram or find channels. It will scroll up all the channels and stop in a minute and store them all in memory. The words may be slightly different on your tv, but the procedure will work. Play around in the menus. You will find it.
Mar 25, 2008 | Televison & Video
Tuning in my orion tv
Do you just mean to select channels, or do you need to have it search for active channels (programming mode)? If just select channels, then most remotes have channel up & down buttons, in addition to the number pad. To select by numbers, use 2 digits: 04, 06, 08, 10, 22 and so forth.
If the set needs to be placed in the setup or autoprogram mode to search for active channels, then the menu functions must be used.
You may be able to find an online manual on Orion's website. Use your TV model number.
Jan 08, 2008 | Orion STV2763 27" TV
Codes for my Philips universal tv remote control
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Sep 16, 2007 | Televison & Video
Orion tv model 1934 only 3, 4 and aux no pic or sound!!!!!!!!!!!!!
Turn the set on, hook the cable directly to the TV, take the remote control and press 1 - 1 and if the TV tunes in channel 11 then your set is fine. If the TV was autoprogrammed when hooked to a cable box then the only channels that will be stored in memory are 3, maybe 4 and AUX. To correct this simply go back into the menu and look for the "autoprogram" option and perform the autoprogram while the cable is directly connected to the TV, without a cable box.
Jul 29, 2007 | Orion1934 19" TV
Orion STV2763 27" TV Logo
159 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
