Question about Dell E193FP 19" Flat Panel LCD Monitor
Monitor goes off and on
Usually at the end of the day after being on 9-10 hours the screen will go black for a second then come back for 25 seconds then go black. It will do this for 5-10 minutes and then be fine for the rest of the work day. Any ideas? Steve
    Scholar:
  • 116 Answers
Yes your backlight is going bad! This is common with an LCD monitor! There are no guarantees with these new items! Sorry I hope that this helps! When a backlight goes bad it will generate enough light to display an image, but it will not hold that charge for very long, it varies based on the manufacturer who sells the Montior!
Posted on Nov 27, 2007
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Screen cutting out
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jun 29, 2010 | Hannspree HH251H 25" LCD Monitor
Screen goes black
More likely to be in the power supply/inverter baord: http://www.lcdrepair.us/E228WFPc-inverter-power.html
Look for bad caps first, but it can also be in the lamp assembly, you will need lamp tester and inverter tester to verify that.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 16, 2010 | Dell E228WFP LCD Monitor
Viewsonic VX710 Monitor scrren goes black
replace all caps on power supply board check values
should not cost more than 20 us. and 1 hour soldering
easy fix but new monitor goes around 100 us.
can you do it???
May 10, 2010 | ViewSonic VX910 19" LCD Monitor
Monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Aug 14, 2009 | Computers & Internet
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Screen goes black after a few seconds
Problems like these happen all the time with LCD monitors. Usually one of two things. Bad Capacitors or a bad backlight. To check this, take a flashlight and point at your monitor (usually at a high angle) and see if you can still see the desktop faintly. If so then its either the back light or capacitor. Backlights shouldnt need replaced too often as they have a extremely long lifespan. Capacitors are relatively cheap and easy to replace, all is required is a soldering iron and an inexpensive trip to a Radio Shack. Though this isnt your monitor, it is a very good tutorial on how to go about replacing the capacitors.http://www.wizardanswers.com/liquidvideorepair.html If it is the backlight, here is another tutorial for that :D http://www.inventgeek.com/Projects/shorts/lcdfix.aspx
Jun 12, 2009 | Proview PL913B 19" Flat Panel LCD Monitor
Monitor problem: screen goes black, then comes in scrambled
It sounds like this one needs component-level troubleshooting, probably in the power supply section. One or more backlights may be going out, too.
Dec 31, 2006 | View and View Technologies VNV AquaView...
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Dell E193FP 19" Flat Panel LCD Monitor Logo
123 people viewed this question
Alun Cox
