Question about Welding Tools
I have 150 mig welder BOC150 and the tem light is on and it stop
  • 380 Answers
Too hot. You have exceeded the duty cycle. Remove the power and let it cool for a few hours.
Posted on Mar 02, 2019
SOURCE:
  • 2712 Answers
SOURCE: Mig replace tip
Pull off the extreme outer nozzle of the MIG gun. Clean the inside of this nozzle with MIG pliers or round wire brush. Unscrew the welding tip. (If it is stuck, try using a pair of pliers lightly). Clean the entire area with a regular wire brush. Screw on the new tip finger tight, but snug. Replace the outer nozzle.
Posted on Aug 27, 2008
  • 3 Answers
SOURCE: mig welder tripping power supply
the breaker could be bad. try to change the breaker
Posted on Jan 16, 2009
luxur4
  • 92 Answers
SOURCE: mig welder powers up but only clicks when trigger is squeezed
1] Remove the power cable from the power. (socket on the wall) remove the top cover there should be a fuse located on the wiring panel.
2] perform all your house keping- like, all plugs and socket are tight, the correct contact tip with the the right wire size, roller/s are also the correct ones for the wire size and are turning if they are turning but not feeding the wire, then, the rollers need to be tightend , get back to us.
Posted on Jan 23, 2009
  • 4 Answers
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Posted on Apr 08, 2009
SOURCE: Toolex 140 mig welder, wont feed wire.
You may have the scew settint your wire tension set to tight. Try loosening the tension and if that doesnt work check the eletrical wire that supplies the power to the roller and make sure it hasnt become disconected.
Posted on Jun 28, 2009
What is the tip thread size of kende 150 mig welder . It's not standard euro torch
are you sure it's not a 1/4" 28 national fine? check the tip by threading it in a thread die
Apr 27, 2016 | Welding Tools
What mig gun is on a Nevada 220BZ Mig Welder
Nevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder ...
www.ebay.com.au > Industrial > Welding > Welders
eBayNevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder Welding ... Nevada Welding machine; MIG Torch; Earth Clamp; Electrode Holder; Safety Mask ..
Dec 20, 2015 | Welding Tools
I have a older centrey 80 mig welder that i am trying to find a new lead and gun assmbly
Century parts are a pain in the **** to find, try to adapt a tweco #1 mini gun on it, you will find parts for it at any welding store. It will cost you around 150 bucks
Nov 14, 2010 | Welding Tools
SIP turbo 150 mig welder instructions wanted
for welding cars or similar thickness steel use it on number1 setting speed 6-7 and practise max and min should be used when you want a bit more power A gose onto number 2 and then 3 these are amp settings and are for thickness of steel to be weled your welder can weld up to 8mm of plate steel on setting 3 max i use 0.9mm gasless flux cored wire great for working out doors the wind tends to blow gas away on standard wire yours is easly converted to gasless as so was mine
Nov 02, 2009 | Welding Tools
Mig welder schematic wanted for magnum auto mig 150 turbo cheers
if you call the maker of the welder you can be sure the one they give you is right and its normaly free and faxed or mailed right to you.
Oct 25, 2009 | Welding Tools
What is required to switch from steel to gas on light duty mig welders
if you mean from flux core wire to gas shielded wire you will need a tank and regulators,and feed hose from the welder to the tank
Sep 06, 2009 | Lincoln Electric LE 83180 Century...
Century mig welder. The wire speed is spinning at max speed as soon as the machine is turned ON. Will only stop when machine is OFF.
My Century 225 mig has lost its power ...with adjustments to max it leaves a high weld deposit and low penertration.
What is the fix ?
Aug 14, 2009 | Lincoln Electric LE 83180 Century...
Excessive wire speed on hobart ironman 250
to find out if you need a new reostat disconnect the wires from it and put an ohm meter on it and check the ohms resistance it should read up and down ohms as you turn the dial.
Mar 02, 2009 | Hobart Welders IronMan 210 MIG 500304A...
Welding Tools Logo
Top Welding Tools Experts
David Soto
David Soto
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
