Question about Hobart Food Mixers
After information on HOBART SE 601 SE601 stand mixer regarding grease!
I have acquired an old but in good condition Hobart SE601 stand-mixer. all Hobart can tell me is that production stopped mid 70s. mainly i would like to know if they require grease or oil in the main gearbox? the newer models use oil and a slinger to spread the oil about in the 60qt machines. what was in the gearbox when we opened it up looked like grease but it was so old that it could have being anything 30 or 40+ years ago when it started in there. also if grease or oil, how much to put into the gearbox?
    Top Expert:
  • Hobart Master
  • 63,565 Answers
YOUR GUESS IS AS GOOD AS OURS WOULD BE . THO THEY DO MAKE A SILICON GREASE THAT IS USED IN THE FOOD INDUSTRY
Posted on Mar 05, 2019
  • 1,378 Answers
SOURCE:
How do I empty and then refill the grease in the gear box of my 30 quart Hobart mixer
Transmission has to be somewhat disassembled, grease removed, lower seal should be replaced and then grease added and reassembled. Not that easy to do. Check www.hobartservice.com for your local Hobart office.
May 05, 2011 | Hobart A200 Stand Mixer
Oil leak
instead of putting a gasket on tell him to take out all of the old grease out that is what has broken down and turning into oil causing a leak and if he can repace the seal around the agitator shaft replace the old grease with a high temp bearing grease or a good quality lithium grease
May 25, 2010 | Hobart A200 Stand Mixer
How to change oil in 20 quart hobart mixer and the type of oil
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
Dec 20, 2009 | Hobart H600 Stand Mixer
Old man needs help with hobart 30 q mixer
it has to be torn apart to change grease and it is grease do not put oil in it. but it all is done from top under cover is the top of transmision the round cover comes of and all shafts need to be removed and I sugest a new main shaft seal and hub seal while your at it.
Nov 29, 2008 | Hobart A200 Stand Mixer
Hobart N50
Some of the N50's were packed with a white grease. It tends to seperate. So the oil portion finds it's way out. It sounds like it is getting into the motor case, and is running down the inside of the column. Hobart now uses a brown clay based grease --- Darina 2.
If the amounts are small, and the mixer is not excessively noisy, I wouldn't be concerned. If you wanted to fix it, the transmission would need to be removed, cleaned, and repacked. For a Hobart tech, 3 hours labor, $45 grease, plus parts.
Jun 19, 2008 | Hobart N50 Stand Mixer
Noisy Hobart N50 Mixer
First, there is a double set screw (one on top of the other - if they are both there) towards the back of the planetary.
Remove the first screw, it should have a normal tip, not pointy. Run the mixer in 1st and adjust the screw, first out then in. Then repeat in 3rd. You should clearly hear a difference.
If not, you probably need to repack the grease in the transmission. The proper grease is called "Darina II". It's expensive ~ $35 per mixer.
Apr 13, 2008 | Hobart N50 Stand Mixer
Hobart A-200 serial # ?
Hi. Your mixer was manufactured in 1967. If you plan on keeping it, take the outer cover off, gently remove the two metal dust caps with a small screwdriver and look into each opening with a good flashlight to determine the quality and amount of grease in the trans. case.
Ideally the grease should almost fill the space with no oil visible. If you need to look further, I suggest that you open up the transmission cover, to determine the condition of the grease that lubricates the transmission. If you find that oil is seperating from the grease. you would do well to remove all of the oil and old grease and replace it with either Shell Darina EP-2, or Chevron FM ALC EP-2 grease. It's a messy job, but it will add years of life to your mixer.
Check the planetary seal, remove, clean and regrease the planetary gearing. With a mixer of this age, you never know if it has ever been serviced since it's manufacture or not. The grease must totaly encapsulate the trans. gears. As the grease breaks down it's level lowers and it leaves some of the upper gears without lubrication, and will result in preventable wear.
Good luck! If you found this solution helpful, please rate it. ricardok45
Mar 02, 2008 | Hobart A200 Stand Mixer
A200 Mixer/Medalist L120 Mixer by Hobart
Where is it leaking grease from?Im a hobart tech and service these mixers.When i go into work i will get you the part # for the grease.You would then have to contact your local hobart branch,tell them the part # and pick up the grease.
Feb 25, 2008 | Hobart A200 Stand Mixer
Old hobart s-30 mixer oil
man you got an oldie but goodie mixer!im a hobart service tech for 8 years and have only seen about two dozen,unfortuantly parts for these units are exhuasted.as for the sight glass they do become cloudy over time and you cant determine the oil level.use a heavy gear case oil.the only way of telling is to drain the oil or if the unit is loud you should probably cange the oil.
Jan 20, 2008 | Hobart A200 Stand Mixer
How do i lubricate my 20 qt Hobart mixer and what kind of oil do i use?
you can call your local hobart branch for the part number,but you use lithium grease in the unit.in order to change the grease the transmission needs to be opened and so does the planetary. i service these mixers alot i work for hobart.if you need any more help/questions let me know.
Dec 23, 2007 | Kenwood KM400 / KM410 Chef Classic Stand...
Food Mixers Logo
90 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
Steve Allison
Steve Allison
Bruce Showalter
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
