Question about Panasonic CT-27HL14 27" TV
Neet a part for Panasonic CT-27HL 14J Television
I am looking for the part number for the front door cover for a Panasonic CT-27HL 14J. I broke off the corner tabs while moving it. Any idea?
  • 99 Answers
Call panasonic, they are great at at solving this type of problem, if you get a good tech rep they will quickly find it for you.
good luck-----------------------tomtaso
Posted on Nov 27, 2007
I have a Panasonic Microwave Model NN-SD277. How do you access the workings of the door opener button? It is broken so the door won't open.
You have to remove the outer cover, the plastic lift levers are behind the door open button / lever. Caution!, panasonic discontinued a lot of those and getting a replacement part can be hard at times. Dont waste your time trying to glue it. After watching people try to glue or epoxy those cheap plastic parts for so many years. I have to warn folks to not waste your time trying. .It will not hold!!!! Look online and try to find a replacement part somewhere. It will be one of two parts. the door open button you push, or the door open lever that the front button pushes against. If you unplug the unit and remove the outer cover simply look behind the front control panel and when you push the button to open the door you will see where it is supposed to lift to open the door. The broke part is your problem, may be a piece laying in the bottom.
Aug 14, 2017 | Panasonic Microwave Ovens
Can't program universal remote to control a 2005 Panasonic HDTV 1080i Model #CT-27HL 14J
If code search method too cannot help you, the remote control won't have a setup code to your TV. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
Feb 22, 2014 | Universal Remote Control GE174Universal...
Universal remote code for a panasonic ct-27g14a
Two things you can do:
Mar 15, 2012 | Panasonic CT-27G14 27" TV
The television CT-27G5 is not recognizing the IR from the remote. I have tested the remote and it is outputing a signal. Is there a reset procedure for the television and remote to put them back in sync?
No reset for that. Most likely the remote sensor inside the tv has gone bad. It is at the front of the main PCB beside the front panel buttons. check for availability. Thanks for using fixya.
Feb 20, 2010 | Panasonic CT-27G5 27" TV
Panasonic CT-36HX42F will not power on
If you remove just the lower half of the back cover (NOT THE UPPER PLASTIC COVER) you will see the power cord which is attached to the circuit board. Next to the power cord is the fuse, but be careful, this is not just a glass fuse you can buy anywhere. To make sure you order the right part go to and go to OEM part finder. typed in your model number exactly how it is on the back and do your search. You will then see every part that is available through them that you can order. If you also notice you will see just above all those parts that they have a board location search. Look at the fuse in question and get the location number from the circuit board and type it into that search and you will have the correct part number shown to you, but if you look there is not a price listed. Copy the part number down and again go to and on the top of the home part you will see a nice search bar where it will say enter part number or keyword here. Type or paste that part number into that and search. You will then be able to see how much the part is and if it is available. I do not work for MCM, but they are a great source in finding exactly what the part number is if your doing it by board location.
Oct 21, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Panasonic television
I had the same problem, however mine was a 32inch. It is a blown fuse. It is not the power cord. What you need to do is find out what fuse voltage you need. Hope this advice helps. I have a panasonic model CT-32SX12C.
Aug 20, 2008 | Panasonic CT-36SX12 36" TV
Panasonic CT-36HL44
is the orange wire a plug in or is it broke off the crt board if so solder back together
Nov 14, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic CT-35HL43 36" TV has NO power
it could be the ac fuse gma 6.3 amp my ct-36hl43 did the same thing cost a dollar for the part 99 dollars laborer
Sep 30, 2007 | Panasonic CT-36HL43 36" TV
Panasonic CT-27HL-14J Chaisis BP416
Do you know how to work on solid state electronics? if not then Im sorry to say you will need to get the assistance of a local tech who is experienced. As these sets are solid state and there are no user servicable parts inside. Good Luck
Oct 16, 2006 | Panasonic CT-27HL14 27" TV
Panasonic CT-27HL14 27" TV Logo
114 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
