Have been using the hard drive for music videos etc been working fine up until this weekend Power supply green light flashes when hard drive plugged in and no green light on hard drive....what could be the problem and are there any solutions???
I have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Could be a bad transformer on the power supply or a bad drive. You could check the voltage coming from the transformer and verify that it is the proper voltage using a fluke meter. You could also dis-assemble the hard drive housing and try installing it in the computer and check if it is working. If you install it in the computer and the drive is not found then the drive is probably bad. If the drive works in the computer then get a new transformer.
You could buy another drive with the same specs and replace the circut underneath the drive with the circut from the new drive, then try it in your new enclosure
If restarting the console does not resolve the behavior, follow these steps:
Turn the console off.
Unplug all the power and AV cables from the console.
Unplug the power cord from the wall socket.
Firmly reconnect all the cables.
Turn on the console.
If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
Also examine the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the RoL flash red.
If the above suggestion dose not yield results, i would use the link provided below to help fix this issue yourself.
Hello.
Most likely this is an output problem. But I have had 1 PS3 that had a bad hard drive and it wouldn't even load to the XMB. So try another hard drive and see if that works. Even a swift smack to the old one may work. If that doesn't work try the video out reset.
Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
