Question about Powerline Ethernet Network Adapter
Orange Livebox and NIC
I have 3 comps - 2 wireless and 1 on Cat 5 served for internet and LAN by Orange Livebox. Wireless is good - no problems.
The NIC Cat 5 connection will hang the livebox if I connect to a comp on wireless? The only way to get comms back is to re-booot the livebox??
The NIC in question is on Win Vista Home Premium
- Intel (R) Gigabit 82566DC looked at all settings and advanced settings and can not find the problem!!
Any ideas?
  • andrew21 Feb 08, 2008
    I have had an Orange Livebox installed, but the Microtechs engineer failed to connect it wirelessly. He claimed my BT Voyager 1010 is not compatable, despite the fact it detects the Livebox (and my neighbour's Sky router).
    Is it corrct that I need Orange's own wireless adaptor or shoudl any 802.11 adaptor work (assuming the Livebox uses 802.11)?
  • Anonymous Mar 28, 2014
    Have new laptop running Windows 8
  • 96 Answers
Sounds like an internal problem with the Orange Livebox NIC controller.
If you have an other router Lynksys/belkin you could try it would isolate the problem definitively
Posted on Feb 10, 2008
I have CenturyLink. I cannot get the Belkin router to work. What to do?
IF THE MODEM GIVEN BY CENTURY LINK is 660 Series then the IP Address of the Modem and Router Will be the same
So before starting the troubleshooting ... Disconnect the centurylink Modem from the Belkin
Step 1 : Connect One of your computer to the belkin ( to any one of the 4 grey ports ) with an ethernet (CAT 5 ) Cable
Step 2 : Open internet explorer
Step 3 : On the address bar type and press enter
Step 4 : If you are at the belkin Router Setup utility ..
Step 5 : On the Left under LAN Setup click LAN Settings
Step 6 : Leave the Password blank and click submit
Step 7 : Change the IP Address to
Step 8 : Click apply changes
Step 9 : Connect the Modem - Router ( to the yellow slot )
Step 10 : Check the color of the light in the Router
Step 11 : If it is solid green .. Check if you have internet
Even though The router comes with a Pre-Set Wireless network many people wont like to use it
if you like to setup a connection
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Dec 26, 2010 | Belkin Wireless Surf Router (F7D2301)
I am installing linskys to my home computer. I follow al of the directions on the linkys cd but when i switch the wire from the modem to the router and plug it back into the tower i wil not have an...
I think you need an extra cat-5 wire.
Plug one CAT-5 LAN cable into the port labeled WAN on Linksys then the other end into the cable Modem where your PC is normally
now take a separate Cat-5 LAN cable adn plug it into port 1 on the linksys - the other end into your PC NIC
Power cycle Cable Modem (remove battery), linksys, PC this will clear the MAC addresses
turn on modem, linksys then pc
loging to windows - open IE on address bar type - this should be the default address of your router (unless you've changed your subnet) in which case I recommend you factory default the route and use default settings. after typing teh 192.1386.1.1 you should see the linksys login
Now try in IE, the routers factory setting for DHCP should work fine without any end user programming from you.
please rate me, good luck
Aug 24, 2010 | Linksys Wireless-G Broadband Router
The wireless icon is orange. Do you know why??
Hi, 1. Unplug the power from the Modem to the Router 2. Plugin back the power into the Modem and wait 60 sec.. 3. Plugin back the power for the Router wait 60 sec.. 4. Plugin a lan cord from the router to the first wired PC 5. See if you can get on the internet 6. Login to the Router and see if the Connection to the WAN is started? 7. If not started then unplug the wired lan cable and reset the router wait 30 secs to 45 secs before unplug the power then plug the power in again. Then connect the lan cable then connect to the GUI for WEB. Make your See if it connects to the WAN. 8. Test the Network WAN -Internet and LAN - Home Network.
Take care
Jul 17, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Unable to connect netgear wg111 adaptor to orange livebox for internet connection
Hi, follow the steps below:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Aug 31, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Problems connecting to internet on laptop
check your IE internet connetion settings follow ff. steps.
1. open Internet Explorer browser
2. go to tools, internet options or options
3. under options, select "connections" tab
4. under connection tab, select "LAN settings"
5. under LAN settings check if "Automatically detect settings" is mark check if not mark it check.
6. click apply to save your settings and click ok
7. close your browser and open it again
if you still having a problem,
try this steps to chek your wireless settings
1. rigth click the wireless network status bar near desktop time & date
2. select status
3. under status, select Properties
4. under properties, select TCP/IP settings and click properties
5. check if "Obtain an IP address Automatically" is selected if not select.
6. click also obtain DNS
7. save your settings and close the properties
8. after saving, wireless will reconnect
9. open your browser for Internet
hope this will help you
Dec 16, 2008 | Linksys WRT160N Wireless Router
Belkin wireless adapter g usb
WPA is safer as all in all it's a lot harder to crack due to being a lot more characters in the passkey. The easiest thing to do would be explain how i have mine set up. And you could compare the 2.. As i have XP Desktop & Vista aswell. So your Laptop connects ok now but is still an unsecure network.. On your Dektop. When you try to connect. Are you entering the 26 character key on the bottom of the livebox?
The main thing to realise with the Livebox is everything is reversible.. And to not worry about changing something..
So let's get this started, When you open up the " Connect To A Network " you can see your Livebox-XXXX. Next to that does it say "Unsecured Connection"? If this is the case then your Livebox is still not properly configured.. What i would recommend doing is starting a fresh with the Livebox, and i explain how to set it all up from Default. icon_smile.gif
IF you don't remember your internet login details then go to "Configuration.adsl" and click My Services then Internet. Your info will be in there. Hopefully you remember your password.. icon_smile.gif
If you don't know how to do a reset of your liveox. Press and hold the "1" button on the back of your livebox. Unplug it from the mains whilst still holding the "1" for 10 seconds. Then plug it back in. [ still holding the "1" ] The lights will flash a bit and after a minute or two it will go back to normal.
Go back to "configuration.adsl"
Username: Admin
Password: Password
If i start from the top section and work down it should make it easier to follow:
My Services>Internet>Connection Parameters Filled In..
Phone Over ADSL> Nothing needs changing
Digital TV> Nothing Needs Changing.
Liveprinter> Nothing Needs Changing.
Security> Associated Devices> Will Be Empty
Firewall> Medium
Wireless Connection> Channel Number> 11
Security Key(WPA-TKIP)> Same As What's On Bottom Of Livebox.
Enable Wireless Lan> Ticked.
Configuration> Update> v5.10.7-uk
Administrator> Change the password while you're there..
Advanced> Wireless> Pairing Time> 10 minutes should be fine.
Your Livebox name can be left as it is.
WPA Security Only
Wi-Fi Easy Pairing.. Might aswell leave it on..
Now if we set up your laptop first.
Go into Connect To A Network. Your Livebox should be there. It also SHOULD say Secured Network. If there is a Red Cross then you will need to do what i suggested yesterday on my previous post.
Go back to connect.. Enter the 26 char. passkey with caps lock on.. And you should be connected no problem.
Now for the Desktop.
when you log on.. In the taskbar in the bottom right should be something to do with wireless networks. Double click this.. If it mentions something about using the software that came with the device.. Then use the software.. If not then windowsXP will show your network. Double click it.. Enter the same 26 character code.. And you SHOULD be connected.
Let me know if that works.. Sorry for the really long post, but detail is something i do quite well... icon_smile.gif
May 26, 2008 | Computers & Internet
ENET Port issue on BEFW11S4 Wireless Router
Try these steps:
1. Make sure the wireless is disabled when you're doing that. It might cause a confusion between the wired and wireless connection.
2. Try to plug it at other ports (1-4)
3. Try another known working ethernet or CAT-5 cable.
4. Set the laptop's LAN card's speed to 10-hald duplex.
Try these and hope it will help you ;-)
Apr 02, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Connecting powerline ethernet adapters through orange livebox
Try to eliminate the problem into smaller parts. Try networking the two via the same power outlet via a multiple power board first in the same room. I don't have much experience with these powerline ethernet but i'm sure the configuration of these will be very similar as wireless router / access points and wireless adapter cards. However what I do know is that your power outlets need to be on the same "phase" of your electrical power system, so if you do this test I suggest (from one outlet board) you know the equipment works and your setup procedure works. then try seperating again and if it still doesnt work, check if your power outlets are wired on seperate phases (depends if your house has 3 phase wiring incoming to your home or not). Try another room or another outlet.
Oct 13, 2007 | Powerline Ethernet Network Adapter
Powerline Ethernet Network Adapter Logo
429 people viewed this question
Top Powerline Computers & Internet Experts
Chris Larocque
Ivan Young
Ivan Young
Are you a Powerline Computer and Internet Expert? Answer questions, earn points and help others
