Misubishi rear projection tv (15 years old)
I have this tv just stoped working i checked the fuses i have a click when i turn it on but then a humm no picture or sound what should i check or do
thanks
    Genius:
  • 1,153 Answers
Do the diagnosis test read at www.ctechnicians.com
Posted on Nov 26, 2007
I have a projection tv its 3-4 years old and in one corner of the tv i have small white dots like stars, it started with just a few and it is now multipling and spreading. What could be wrong with the tv?
Very expensive repair must be replacement of the light projection engine block to sloved this problems.This problems are happening to many tvs brand 50-70 up DLP projection tvs like Samsung,Toshiba,Misubishi,Sony because they all put in the same problems IC design on their projection tvs on their light projection engine block.Talk to Samsung,might get some help with the repair.
Feb 16, 2011 | Samsung HC-P4752W 47" Rear Projection...
Have a misubishi ws55859 green light blinks will not turn on it all started when the tv was unpluged
The dm board power circuit has gone bad and would require many capacitors to be changed. This board is a box (metal grey) on the left extreme as viewed from rear next to input connector board. It is not recommended as an abinitio DIY Project. Caps faults are difficult to find and require an ESR meter. Call for professional help and should cost 180 to 220. Check it out at www.fixurtvs.com for more questions and price quotes.
Feb 26, 2010 | Mitsubishi WS-55859 55" Rear Projection...
Have a Mitsubishi WD-62327 DLP projection TV. It is a few years old. Would not turn on. Blinks red - 3 short red blinks then 1 longer blinks - and repeats. We have disconnected everything, unplugged,...
if you hold the input and menu button for 5 seconds it will flash you a code 36 is the lamp fan / dmd fan has gone bad. pretty common. not hard to change but will cost 100 in parts and whatever labor may be
Jan 18, 2010 | Mitsubishi WD-62327 62" Rear Projection...
I have a Magnavox projection screen tv. The tv
Will you have got a lot of years on this unit. There could be a lot of things wrong here are some things to check.
SMD capacitor 2009 on Small Signal Board
Check fuse on SSB location 1003
Check resistor 3306 15 ohm surface mount
audio output IC 7700 on the Small Signal Module
May 15, 2009 | Philips Magnavox 51MP392H Rear Projection...
Will not turn on 15 years old
i was watching tv and the tv just went dark. No bad weather. The tv will turn on but no picture or sound. please help asap
Apr 21, 2009 | Hitachi 60V500 60" Rear Projection...
46 in hitachi projection screen -15 years old-won't turn on
Good Day;
If you don't hear the relay click suspect Q003. No power suspect Q912, Q914 & I901. Good Luck, big IRISH.
Aug 01, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Misubishi ws-55711 rear projection crt. Looks like the green tube has gone out of alignment. The two tubes red and blue have one image and green tube has a curved image. What is the solution. The tv is...
Have you looked at replacing the convergence memory chips in your TV? The part # will be stk392-110 or possibly stk392-120? There will be 2 of these parts on a board standing upright. The part # will be printed on the part.
Apr 01, 2008 | Televison & Video
ProScan rear projection
Proscans are manufactured in conjunction with RCA what is the chassis number of your set? I can help you out if you can provide the chassis number. Should be located on the back cover of your set.
Mar 02, 2008 | RCA P61960 61" Rear Projection Television
Samsung HCN473W 47 in. Rear Projection can't turn on
i know this is a old problem but in case anyone in the future here has this problem, the problem lies in your convergence board ,mainly the stk`s are shot ,you can buy new STK`s for around 15 to 20 dollars and then will need some one to take old ones of and resoldering the new ones on.
anywho if you have this problem unplug or remove your convergence board and then turn on tv and you will see a picture, all colours will be out of convergence but when you put the fixed board back in colours should realign, or you may have to realign a little yourself.
only reason i am posting on this old problem is because was just given this tv samsung hcn473wx/xac for free and decided to fix it and it now works well.
micheal rose
Sep 26, 2007 | Samsung HCN473W 47" Rear Projection...
Pink horizontal line when the tv is powered on.
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Jun 13, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Televison & Video Logo
215 people viewed this question
Top Televison & Video Experts
