Washing Machines Logo
Jo Harris Posted on Mar 01, 2019
I cannot open the door of My bosch logi xx 8 frontloader. I've been through the Bosch helpdesk process and it still won't open. Its Friday and I need to open the door !!!!
Kevin Gibbs
Level 1:
  • Contributor 33 Answers
  • Posted on Mar 01, 2019
Kevin Gibbs
Contributor
Level 1:
Answers
33
Questions
Helped
10291
Points
85
Unplug unit for 1 hour then plug back in
5 Related Answers
Anonymous
  • 130 Answers
  • Posted on Jan 23, 2008
SOURCE: bosch frontload washer will not drain
Hello Mamma5, It sounds like the drain pump is either seized or jammed. The drain pump has an anti jam device in it. Since you have figured out how to get into the drain pump, try turning the inpeller in the back. It will be a little hard to turn as the magnets in the motor will fight you on this. Look close in case there is anykind of thread wrapped around the inpeller. If so, then you can free the pump. If you cannot free it to run, advise the repairman what you found so he can bring a drain pump with him.
Hope this helps.
mcpcis
  • Posted on May 23, 2008
SOURCE: BOSCH Washing Machine -Door Seal
1) remove the tension ring under the rim of the seal at the front
2) flip the whole seal into the drum so that you can get at the inside of the seal
3) remove the tension ring hold the seal to the outer tub
4) reverse of the process to put in the new seal
Its as simple as that.
Anonymous
  • 3741 Answers
  • Posted on Aug 31, 2009
SOURCE: i need a bosch WAS24466GB user manual
click on the link below and download the manual,if asked you will have to enter model number or else you can download user manual directly from the link:
bosch user manual
thanks.
Testimonial: "thank you, that was very helpful"
Anonymous
  • 375 Answers
  • Posted on Jan 13, 2010
SOURCE: Bosch classic xx 5 mintues into the wash, stops and tripps elec.
Hello Sir,
I think that this is due to a faulty Main box Fuse. This usually happens when the heating elements of the washer go on. Try to inspect for faults, cracks or breakages in fuse box or in switches.
Thank you Sir,
Have a nice day.
Testimonial: "Mr Dhar,.Very helpful, I have got something now to go on to solve the problem. Thanks a lot. "
Anonymous
  • Posted on Jan 17, 2010
SOURCE: Bosch Classic xx dishwasher; not
slimline classic xx bosh dishwasher not pumping out water??
1helpful
Bosch classic xx dishwasher door won’t close but the cycle runs can anyone help
Door lock is jammed on , take front panel and console panel off , with a screwdriver, flick door lock mechanism to open, spray with wdr0 and it should work
1helpful
Bosch washing machine logi xx7 no power cant open door. fuse ok
Check power at outlet and make sure you are getting power to the machine. If you are then the board on the machine may have had a surge and burned out
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
I can't figure out how to reverse the door on my
You need a left sided hinge kit...here is the link to the part from Bosch http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodlg.htm?Maktx=wtz1260&eshoptype=A
There is a PDF on their site under "support" and your model number wtmc3321us that shows this on page 8. Hope this helps you! :)
Jun 11, 2012 • Dryers
Bosch Nexxt 300 has error code E-13 and the door is locked. turned on/off, unplugged, removed the drain hose to see if it is blocked, but ok. but still won't unlock. Is there someway to unlock the...
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
Where do I find the pcb on a Bosch dishwasher classic xx?
Check at front door top. You may have to open the screws around the door.
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
