Question about Pioneer DV-C503 Multi-disc DVD Player
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When you hit the open/close button the carousel opens up and keeps turning,doesn't stop turning.when does stop it then closes before you can get a dvd or cd entered into it. any adjustments or anything can be done to correct. didn't start doing it till my 6 yr old didn't get one of her Disney movies in the track and closed the tray. i tilted the unit and got movie out
  • cal57wyo Dec 10, 2007
    CD stuck behind tray. Tray can not close.
  • buster1 Dec 31, 2007
    We do not have a DVD lost or stuck in our player. If you hold the tray open it will stop turning the carousel sometimes and allow you to put a DVD in then. Now it won't play it says only loading then stops.
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Posted on Mar 08, 2008
How to change the Pioneer DV0-C503 DVD player from region one(US) to zero(region free) Thanks !
1) Turn on without any DVD inside.
2) push setup button.
3) go to general tab.
4) set the "Setup menu Mode" to Basic and leave the window that shows "expert" and "basic" options open.
5) press Display to see the actual region number.
6) press CONDITION MEMORY and then the Region number do you want to set.
7) press Display again to verify that the region have been set.
That should be it!
Feb 27, 2011 | Pioneer DV-C503 Multi-disc DVD Player
IT WILL OPEN AND SHUT IMMEDIATLY
There is probably a loading belt that has become stretched and the tray is not completing the cycle, " meaning it is not opening all the way and ends up closing just as fast " this a tricky repair best suited for a professional.
Dec 29, 2010 | Pioneer DV-C503 Multi-disc DVD Player
Pioneer model # DV-c503 will play DVD but does not play CD's anymore.
The problem could be dirt on the surface of the lens.
Use a dry cotton bud to clean the surface of the lens, this you have to do gently because the lens is fragile.
If otherwise you have to change the lens.
Try websites Shopjimmy.com,Ebay.com to buy parts for replacement..
May 28, 2010 | Pioneer DV-C503 Multi-disc DVD Player
Open and close door opens and closes immediately will not stay open
There is a small strap that looks like a black rubber band that actionate the door mecanism. open the cab and clean it with qtip and alcohol, otherwise replace it, you'll find some at local electronics parts shop...
Oct 12, 2009 | Pioneer DV-C503 Multi-disc DVD Player
How do I unlock my Pioneer DV-310-s so it will accept all dvds, thanks.
Here is how to Make your Pioneer DV-310 regionfree.
Use this link and go there.
http://www.pioneerfaq.info/index.php?question=Firmwares
Search for file YJA8703A almost in the bottom under DV-310.
Download and burn on CD with nero,make sure the CD is being closed after burning.
The just mount the CD in your DVD player and press play.
#1. Press upgrade.
#2. Wait,don´t touch anything now.
#3. The tray will open after about 5-10 sec,take out CD.
#4. Player will uppgrade under about 1-2 minut,then the tray will close by it self,and the player says "CLEAR".
#5. And now here is the secret. When player says "CLEAR" ,push and HOLD the "enter button on THE PLAYER until it turns off(about 5 sec).
And there you go,standing infront of your brand new Multi regional Pioneer DV-310.
At least this worked great for me.
Good Luck!
/Jiinsen
Aug 08, 2009 | Pioneer DV-310 DVD Player
Pioneer Dv 285 powers down after 15sec
Hi There, I've got the same problems with my DV 285. My power started going off approximately 5 to 10 minutes into the DVD. The only button that seems to work is the OPEN/CLOSE button. Once the tray closes, the unit shuts off. I can't even use the on/standby button to turn it on.
Feb 22, 2009 | Pioneer DV-285-S DVD Player
Dv-c503 pioneer dvd player
the magic eye on the door opener in been obtruated by something .. like a small object stuck on a cd or someone might just open the door and let something in it .. stuck on the slidetrack ..and interfer with the sensor .. maybe kids???
Dec 30, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Will play dvds but not cds
your DVDneeds to be adjusted take out the tray turn over the lens there are two shiney screws to the bottom of the lens the one to the right is for dvd and the one to the left is for cd turn to adjust. good luck.
Apr 02, 2007 | Pioneer DV-C503 Multi-disc DVD Player
DV-C302D - Carousel not opening
First. Unplug the DVD for 30 seconds, plug back in and turn set on, sometimes it helps. Second, some CDs may have some rough spots around the inner and outer edges. If your DVD has it, this unit may reject the CD. To remove these rough spots, rub the edges with a pencil or ball-point pen, etc.
Jan 19, 2006 | Pioneer DV-C302D DVD Player
Pioneer DV-C503 Multi-disc DVD Player Logo
764 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
