I just recently started to experience a problem with my unit. When I try to insert a DVD or a blank DVD I get a message : "UNKNOWN DISC PLEASE CHECK DISC AGAIN". I have tried several DVDs several times with no success. I've had this unit for some time and had no previous problems with it. This just started recently. What can I do?
-   Yep. Same problem with my GoVideo VR4940.-   rania11
Mar 16, 2009
-   I have same problem with VR 4940 model.Someone suggested bad processing board for the dvd recorder.Do anybody know where you can purchase a reasonable processing board?-   mrspeedy1011
Feb 13, 2009
-   I just recently started to experience a problem with my unit. When I try to insert a DVD or a blank DVD I get a message : "UNKNOWN DISC PLEASE CHECK DISC AGAIN". I have tried several DVDs several times with no success. I've had this unit for some time and had no previous problems with it.-   Guest
Dec 28, 2008
-   I was initilaizing a disc, then stuck a video tape inside and pressed the stop button and play and others, then my initializing froze and manually shut power off by holding in power button then after that, It won't recognize dvd-r, rw or an actual dvd movie, it just spits it back out.
-   fuchangster2
Dec 21, 2007
-   I have the same problem and it just started. I have had the machine for a few months and have played both VCR and DVD recordings with no problem. I tried to copy a VCR recording to a DVD disc and that is when I got the error message. I now cannot play a DVD or insert a blank DVD but can play an audio CD. I can still play VCR recordings. It looks like several persons have the same problem but no one seems to have a solution.-   lm130
Try running a DVD cleaner through it and see what happens. You can get one at Walmart for under $10. If that doesn't do the trick then take it to someone that can open it up to clean it.
I inserted a blank dvd+r for thr purpose of recording a tv show. The screen on the gpovideo has been...
(More)
I inserted a blank dvd+r for thr purpose of recording a tv show. The screen on the gpovideo has been reading initialize for about n hour.What do I do?
My Go Video DVD recorder, model # R6740 won't open. Any suggestions? I've tried unplugging it and...
(More)
My Go Video DVD recorder, model # R6740 won't open. Any suggestions? I've tried unplugging it and starting it back up. Using remote or manually, it just keeps portraying OPEn, then LOAD. Thanks!!
I have GOVIDEO VR3845 DVD Recorder + VCR for few years and had no problem with it until today. I was...
(More)
I have GOVIDEO VR3845 DVD Recorder + VCR for few years and had no problem with it until today. I was doing a regular recording onto a dvd disc when the machine froze during the writing info mode after the recording. I was able to turn off the machine only by unplugging it. After turning the power back on, I am now unable to put in any dvd disc, old or new, commercial or self recorded ones. The machine kicks it out with the message on screen: unknown disc, please try diac again. I have try turning the power on and off, and resetting the machine without any success. Any suggestions?
does not recognized disc of any kind when placed in the dvd drive. I have not used this system in...
(More)
does not recognized disc of any kind when placed in the dvd drive. I have not used this system in several years because of this issue can it be fixed?
