SOURCE: cartridge error on printer lexmark x3650
If cartridges are not original or are refilled, use new original cartridges.
If the cartridges are new and original, try cleaning the metal sensor inside the cartridge carriage.
If still no luck , contact Lexmark using the number listed on the owner manual.
Contact Lexmark -- Lexmark United States
Contact Lexmark -- Lexmark UK
Customer Support - Lexmark
SOURCE: lexmark x4650 how disable ink level ... won't print after refill
All printer mfgrs main business is selling ink and toner.
They couldn't care less about the printer itself.
SOURCE: Reset Lexmark 36 Black cartridge?
BINGO just refill my 36 and printing :) just place tape (2) on the bottom the outside points
ONLY THE ONE OUTSIDE BOTH SIDES :) :) :)
HP his something like this too. 2nd try BINGO IT WORK drill right hole place tape back over refill hole LOL
SOURCE: Lexmark X4650
Here is how to align your print cartridges
Using the printer control panel:
1 Load plain Letter-size paper.
2 From the printer control panel, press tools , and then press ok.
3 Press the arrow buttons until Align Cartridges appears, and then press ok. An alignment page prints.
Using Windows
2 Do one of the following:
• In Windows Vista, click the windows globe (start button) .
• In Windows XP and earlier, click Start.
3 Click All Programs or Programs, and then select the printer program folder from the list.
4 From the printer folder, click Maintenance Align Cartridges.
5 Click Print.
6 Follow the instructions on the computer screen.
Using Macintosh
2 From the Finder desktop, double-click the printer folder.
3 Double-click the printer utility icon.
4 From the Maintenance tab, click Print Alignment Page.
5 Follow the instructions on the computer screen.
If you aligned the cartridges to improve print
SOURCE: Lexmark x4650 says "print cartridge missing" but just replaced.
CLick on Start, printers and faxes, right click on your printer icon, click on properties.
There should be a tick box to allow you to reset the cartridges to new....
Sometimes the ink
cartridge carrier won't automatically move to its loading position even when
the printer is on and the cover is open. Follow the steps below:
1. Unplug the
printer from the power source.
2. With the cover
open, hold the solid white strip that connects from the carrier assembly to the
ink cartridge carrier and gently slide the cartridge carrier to the center of
the printer.
3. Remove the
used cartridges.
4. Load the new
cartridges. Close the cover.
5. Plug the printer back to the power source.
Sometimes the ink cartridge carrier
won't automatically move to its loading position even when the printer is on
1. Unplug the printer from the power
source. 2. With the cover open, hold the
solid white strip that connects from the carrier assembly to the ink cartridge
carrier and gently slide the cartridge carrier to the center of the printer. 3. Remove the used cartridges. 4. Load the new cartridges. Close
the cover. 5. Plug the printer back to the
power source.
The Lexmark manual says: Remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. See pic below...
Hi
Please open the lid which is located on top of the printer. Also see this
picture of Lexmark X4650 Printer showing the open lid and cartridges. Just
remove the cartridges and install new ones
After downloading the
drivers save them and install them. Hope this helps...
Daniel
