Question about Frigidaire 14 Cycle Tumble Action Washer
Frgidaire Tumble action washer
Tub does not turn over, when machine is accessed from the back the tumble action attemps but does not complete. Whene helped it will tumble. It acts as though the motor has lost power enough to tune the tub. There is a sound in the motor that does not sound smoth, but rough or as gravel maybe. The motor will try to turn clockwise and when it cannot it will attempt to turn counter-clockwise and when it cannot it will stop trying. If tub is turned manually motor continues to turn in that direction but when manual help stops the motor slows and stops trying to turn.
  • jadiemizo Jun 13, 2008
    My Frigidaire Tumble Action Washer is making a grinding
    noise when as soon as I try to start it.
    It will on make the grinding noise and the washer will start.
  • 213 Answers
Because of the grinding noise your talking about it sounds like the motor bearings are bad which would require motor replacement. but, thats normally not what cause the " not completly turning problem" your having. general thats cause be the motor speed control not sending the proper power to the motor. remove the belt and turn the motor by itself to see if the noise is really come from the motor and not the back of the tub. if it is the motor, replace the motor. if it coming from the back of the tub the replace the motor speed control. the noise coming from the back of the tub would just be the ball bearings and they do make some noise on this model but you wont hear it when the washer is running
Posted on Nov 27, 2007
Our tumble action front-loader washer just recently started leaving black marks in the pattern of the holes on the inside of the washer drum- We ran it twice without anything in the washer, and it still...
Thanks for stopping by:
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some de-greaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa!!
Aug 03, 2011 | Frigidaire 14 Cycle Tumble Action Washer
Need to replace water pump in Frigidaire tumble action front loading washing machine. Parts are hard to reach/get to. Is there a step by step for the process available?
After unplugging the machine, turn it around and remove the rear cover, After that all the parts are relatively easy to access and it will be obvious how to replace the water pump.
Feb 13, 2011 | Frigidaire 14 Cycle Tumble Action Washer
My tumble action washer spins out of balance no matter if it is leaded with clothes or not
turn the tub by hand and see if it wabbles if so only one fix replace inner tub.
Sep 28, 2010 | Kenmore 43142 Front Load Washer
Frigidaire Tumble Action Washer buzzing door lock
you might have a damaged door lock might be jammed in the closed position,and should be changed
Feb 06, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Loose drum bangs during spin cycle turn by hand with nothing in drum and still bangs?
your front drum support blocks have failed. remove the tub and, replace or, rebolt them in place so they hold the drum front in place.
Jan 25, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire Tumble Action washer won't complete the final spin. leaves clothes soaking wet.
Had the same problem and fixed with ease. The problem is with the door lock. There is a secondary locking mechanism that kicks in for the final spin due to the high speed. When the secondary lock goes bad the washer will not do the final spin. The replacement part is under $40 @ .
Dec 08, 2009 | Frigidaire 14 Cycle Tumble Action Washer
I called in an electrician/plumber - thanks !
Jul 01, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire 14 Cycle Tumble Action Washer Logo
102 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
