Question about IBM ThinkPad X60 Core Duo 1.83 GHz RAM 1 GB HARDDRIVE 100GB Floppy (1709-97U-05) PC Notebook
I have a compaq presario 1200xl118 laptop computer that needs a small harddrive for it.
Dear sir: i have a laptop computer that is a compaq presario 1200xl118 computer . i have a slight problem . i downloaded off disc winxp but had some problems with a missing driver hraidsk1. as a result i then put winme on it an it took that with ease. but i have a problem with not being able to get rid of the winxp partition. i have run win98 disc to get rid of the partition for winxp an it worked the first time the 2nd time it did not an the third time etc. so how do i erase the partions that were setup for winxp or how do i erase the entire harddrive so i can start fresh without buying a new small harddrive for the computer. an ?#2. can i put a 10gb harddrive in my laptop if i upgrade it. any help would be appericated.
  • 383 Answers
Go to start , control panel, add and remove look the hard drive of winxp and hit remove.
Yes u can up grade on your lap top just take it to some one that is willing to work on the mother board.
Posted on Nov 26, 2007
Cq56 reset bios password
You will have to remove the power cord, remove the batteryand remove the CMOS Battery that is located on the motherboard. On mostcomputers you will have to take the laptop apart to get to the cmosbattery. On some systems it looks like a silver nickel that you will needa small flat head screw driver to pop it out. On other systems it will beinside a vinyl covering and has a cable that plugs into the motherboard. Once you remove the CMOS Battery, let it sit for an hour or two then put itback in and put the laptop back together. Boot the machine and you'llprobably have to go into the Bios or System Setup because the system will haveforgotten the date, time and password.If the password is not reset then you might have to go and remove a Pin from the password jumper on the motherboard. I would consult the user manual and see how to do it.
Apr 28, 2012 | HEWLETT-PACKARD Compaq Presario CQ56-110US...
The screen was cracked, I had it replaced and now it is saying no hard disk its a compaq laptop
Go to BIOS and check whether the harddrive is detecte in BIOS.If it is not detected then the harddrive is either missing or there is a problem with the hard drive connection.Reconnecting the same may resolve the issue
Jan 04, 2011 | Compaq Presario CQ60-220US PC Laptop
How can i reset my laptop. it wont turn on at all, and it has been a while. It is an old laptop and i just want to get the pictures off of it... is there a reset button or anything?
unfortunately no there is not but if you take it to your local specialist computer store they will be able to get the pics off for you.
hope this helps and good luck with the problem and by the way don't forget to vote for this solution.
Nov 10, 2010 | HP Compaq Presario V2000 Notebook
Computer gives cutting out
the harddrive will cut out if gets to hot. need to open up at fans and clean the dust out. Your harddrive may also be cooked also- will need replaced
Dec 14, 2009 | Compaq Presario 700 470024-192 Notebook
How to add RAM to HP Compaq Presario Notebook v5101us? How do I access/open the notebook (back) to replace the RAM?
There should be two or three small covers on the bottom of your laptop. One covers the harddrive, one covers the memory slots and a possible third cover will cover the wireless card.
Oct 15, 2009 | HP Compaq Presario V5101US Notebook
Ctrl+Alt+Del to restart error
Is it a black screen right when you boot your computer? If so this could be a fatal disk error and the harddrive has crashed.
There is no easy fix other than to replace the harddrive.
Oct 05, 2009 | Compaq Presario 700 470024-192 Notebook
Rebuild Compaq presario M2000
It comes in Harddrive. contact your nearest HP service center they can help you in getting a recovery disc. Its free in warranty or you have to pay a small amount.
Sep 07, 2009 | Compaq Presario M2000 Notebook
Compaq Presario F700
IT CAN BE FIXED.. HANDS ON IS THE BEST WAY . LETS GIVE THIS A SHOT. COMPAQ NOT GOING TO HELP YOU THEY WANT YOU TO BUY ANEW ONE IF IT WORK WHEN IT HAD VISTA , IT WILL WORK NOW, I AM SURE OF THAT. YOU MIGHT HAVE TO HAVE IT COMPLETELY TAKEN APART AND RESET IT , BUT THATS ANOTER STORY , FOR now remove the battery and remove the ram/ memory card, then remove the hard drive , a sigle screw should remove the hardrive memory as well then i want you to hold down the power button for about 3 minutes , then insert harddrive only press power, if you hear a beep good sign if th power button remains after the harddrive is installed, hold power button till computer turns off then install ram memory USE YOUR POWER CORD THREW OUT THIS PROCESS freddiemccly@yahoo.com your computer can be fixed i know its easy said then done ITS MINOR but a tech will tell you the total opposite
Jun 02, 2009 | Compaq Presario 700 470024-192 Notebook
Installation problem
It means the install cannot see or detect the hard disk and is caused by :-
Incorrect BIOS setting for the hard drive.
or
A faulty hard drive.
or
The hard drive is not seated correctly on the hard drive connector.
Test the hard drive in another laptop or attach the hard drive to an USB hard drive adapter and plug it into a working computer's USB port, if it see the drive as an external drive and you can copy and delete files to this drive then it is OK and the fault is with the laptop.
Dec 29, 2008 | Compaq Presario Notebook
Laptop harddrive
see if you want the data from this harddrive what you can do is bue external harddrive casing and remove the harddisk from laptop and install in the casing and take the backup.
Nov 30, 2007 | HP Compaq Presario 1700T Notebook
Computers & Internet Logo
76 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
