Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Kenmore Quietguard Plus/Ultrawash - Kenmore
Stock #16759
Water won't drain fully from bottom, however, it does not overflow - I am sure it is clogged, but where the heck is the drain?
TLisa
  • 2 more comments
  • BCDelica Dec 08, 2007
    Same problem with QuietGuard3, have removed drain hose and checked - it's clear! With the hose on the output side removed it moves only a very little amount of water.
  • bdwheels Nov 22, 2008
    Same issue , Dishwasher runs fine but all the water will not drain from
    the bottom. Have to reset it to dry a couple of time and then it will
    drain.
    Hose is clear checked and replaced. Think something is not working
    right with drain pump, however have no clue where to begin with that.
  • tinkers3 Jan 20, 2009
    Washer drains at end of wash cycle, then slowly fills with water again even though cycle is finished. Takes about 20 hours for the entire bottom of washer to fill with water. Run drain cycle only, and washer fills again over next 20 hours or so. Is this perhaps from a leaking check valve?
  • Anonymous Mar 28, 2014
    user manual
    Problem Solver:
  • 19 Answers
Drain hose may be partially clogged or kinked up. ensure that the hose is not bent up thus restricting the flow of water out.
Posted on Jun 10, 2008
Water is pooling in my kenmore ultrawash and it won't turn on either. I need to know if there's anything I can do to drain the water because I think it's refusing to turn on on account of that water p
First unclog your sink drains and the drain hose from the dishwasher. Once you are certain they are clear... Then you can do a couple things to remove the water. dip it out, or siphon it out.... or perhaps use an electric pump.
Dec 01, 2014 | Kenmore 24 in. Elite UltraWash Built-In...
How do I remove the motor pump on a Kenmore Ultrawash - QuietGuard "Deluxe"?
You may be able to find a solution with this video. Be sure to check the comments ... your problem seems very common.
Dec 29, 2012 | Kenmore Dishwashers
Kenmore Ultrawash Quietguard Deluxe Problem
kenmore washers nothing but problems, my washer says clean and will not do any cycles...... less that 2 years old
Oct 21, 2009 | Kenmore Dishwashers
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
I have a Kenmore Quietguard dishwasher, only a few years old, and it won't drain. I pulled it out and checked the drain hose, could not find a clog. I took the basket and sprayer out, couldn't find any...
I have a Kenmore Quietguard portable that won't stay connected to my kitchen sink faucet. Checked all I can and continues to spray the wall and me without staying attached securely to the faucet adapter. Help!! Any ideas?
Jun 17, 2009 | Kenmore 24 in. 15162 Built-in Dishwasher
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Nov 18, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
780 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
