Question about Apple iPod MA446LL/A MP3 Player
When turning on my iPod keeps saying to go to the Apple web site for support
My ipod will work for a while but most times when it is turned on I get the message stating the Apple web site support address. What's wrong?
To reset an iPod with a Click Wheel, including: when turning on my iPod keeps saying to go to the  - ipodnano3.jpg ipodnawhen turning on my iPod keeps saying to go to the  - ipodmini.gifss= ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Posted on Dec 20, 2007
I want to reset my ipod because it is not responding
alandtonipea:
From the Apple support web site article HT1320 (click here):
2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Thanks for using FixYa
Feb 16, 2011 | Apple iPod MA446LL/A MP3 Player
My ipod 80gb is saying apple.com/support/ipod
Try resetting it. Sometimes that's all it needs.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) ipodg1-2.gif ipodg3.gif
Feb 12, 2010 | Apple 20gb Ipod Mp3 Player With Click...
Ipod touch is not being reconized by computer and will not sync to my pc
Chances are, you haven't unlocked your iPod from the passcode lock yet. Unlock it first and try again. It'll be more convenient if you turn off the passcode lock for the moment that your syncing, and turn it on again after.
If this thing doesn't work, I've searched the perfect answer for your problem, straight from Apple's site.
Click here or use this web address: http://support.apple.com/kb/HT1852
I hope that helps.
For more iPod touch / iPhone tips, click here.
Feb 10, 2010 | Apple iPod touch
My ipod will not turn on now again. all i get is a redx in a circle with a apple web site name how can i fix this with out going to the apple store and spending $ 80.00 on it again
  1. Disconnect iPod from your computer.
  2. Manually put iPod into Disk Mode as explained in support document 93651.
  3. Open the latest version of iTunes and connect iPod.
  4. Restore iPod as explained in support document 60983.
Nov 02, 2009 | Apple iPod classic MP3 Player
My ipod says www.apple.com/support/ipod when i turn on my 160gb ipod it reads a big red x and the apple.com/support
This indicates that the hard drive inside the iPod classic has gone bad.
Check Apple's Warranty web page to see if your iPod is still under warranty: https://selfsolve.apple.com/GetWarranty.do
Simply type in the Serial Number located on the back of the iPod, and your location. Who knows, if you are lucky, you may be able to send it in to get it fixed/replaced for free.
May 27, 2009 | Apple 20gb Ipod Mp3 Player With Click...
Apple iPod Nano 3rd gen won't turn on nor charge
If you guys still have this issue, I would strongly recommend going to the following web site:
http://fixyouripod.weebly.com/
There is an instructional video on your exact issue. :) good luck. I hope it's not too late for your iPod's
Mar 17, 2009 | Apple iPod nano 3rd Generation
Ipod nanao 2 gb problem
Have you tried plugging it into your computer and restoring the programming? Also, you can try pressing the menu and the center button at the same time for 10 seconds. It should go black (turn off) and then turn back on with the Apple logo. If this doesn't fix your problem, you got something wrong with the hardware, not software.
Jan 19, 2009 | Apple iPod nano MP3 Player
Have you tried to reset it by holding the middle button as well as the play button in at the same time for about 10 seconds... i had a similar prob but it was due to my hard drive...
Feb 10, 2008 | Apple iPod nano
Ipod
Your iPod Won't Turn On" from the Apple Support Site provides in-depth instructions for troubleshooting an iPod that won't turn on. Apple recommends that you: 1. Make sure the Hold switch is off
2. Make sure the battery is charged
3. Reset iPod
4. Let iPod's battery drain
5. Update iPod's software
6. Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
7. Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
8. Try connecting iPod to the built-in port of a different computer to see if that works.
"iPod Stops Responding or Won't Wake From Sleep" from the Apple Support Site notes that you need to "charge your iPod, then reset your iPod" if it won't turn off or wake up.
Dec 11, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
104 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
