Question about Hitachi 53FDX20B 53" Rear Projection Television
Philips 46" projection TV. "HELP"
I got this tv at a storage unit action so I know nothing about it exept model# 55P9161004 now the problem there is a 1/8 moon of black on bottom and top and the colors are seperated what is the best thing for me to do and what will be the cost?
  • 1,153 Answers
Re: philips 46" projection TV. "HELP"
You have problems in your vertical area and also sounds like convergence issue. This will need much work on board.
Posted on Nov 26, 2007
0 characters
3 Points
My philips 46pp9302 picture looks green ive lined up the blue and red colors but dont know whats
The tv have a problems known as a convergence problems,it dead.The tv color lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost like $300-350 for parts and labors.
Oct 27, 2010 | Philips 46PP9302 46" Rear Projection...
Philips 46 in rear projection tv has too much green. The bulbs are good but adjusting the color does not help.
this models have coolent issues. I would tke off the front screen very carefully , as it may seperate , get a friend . Do not scrach the screen. then look down inside the units CRT's (Cathode Ray Tube) and see if its cloudy or fuzzy looking . While there look at the blue tube as well. If its fuzzy replace the coolent.
Jul 08, 2010 | Philips 43P8341 43" Rear Projection...
46'' philips rear projection tv, red shadow
Thats caused by failed convergence ICs. You can get the DPTV305-DPTV345 convergence repair kit from which also applies to your model. The kit contains the parts and the CD with instructions.
Jan 02, 2010 | Philips 46PP9302 46" Rear Projection...
I lost my picture I still have sound but no picture.
I have a Philips Magnavox Projection TV.
I had dish satelight install on my TV. It worked well for two days, then the picture started showing in a square box. I ffixed the convergence and it seemed okay. The next day I turned on the tv and it had sound, but no picture. When I press the status button, the picture would come on then go right back out. Now I don't have any sound or picture. Here is the model information:
Brand: Philips Magnavox
Model #: 9P6040 C104
Serial #: 51190366
Chassis # PTV843
Manufactured: Nov. 7, 2000 (3910K071H)
TV Receiver Listed: 347K E10839
Amps: 3.7
HZ: 60
V: 120
Can someone please, please help me!
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Beeping noise when I turn on my TV just added a kit for the "chirping set" problem.
Hope this helps,
Dec 03, 2008 | Philips 46PP9302 46" Rear Projection...
Projection tv
I wonder if yu are still dealing with this problem so I can help you
Jun 21, 2008 | GE 46GW 948 46" Rear Projection Television
Hello my projection screen is cracked and in need to know where i can get it fixed and how much will it cost.
Dec 25, 2007 | Hitachi 51F500 51" Rear Projection...
Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
Oct 19, 2007 | Philips 46PP9302 46" Rear Projection...
Hitachi 53FDX20B 53" Rear Projection Television Logo
29 people viewed this question
Top Hitachi Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Projection Television Expert? Answer questions, earn points and help others
