Home | MSI | PT880 Neo FSR Motherboard | Setting up XP on MSI PT8...
MSI PT880 Neo FSR Motherboard
Problem for MSI PT880 Neo FSR Motherboard
Setting up XP on MSI PT880 NEO motherboard
By maartenw - usenet poster
I built a system using an MSI PT880 NEO motherboard. Other details:
Pentium 4, 2.8 GHz
1 GB RAM (2x512) PC 3200
ATI Radeon 9250 AGP card
USB/1394 PCI card
Two 250GB PATA hard disks (one is UDMA 133 and the other is 100) running in
master/slave configuration.
AMIBIOS A7043 VMS, ver 1.6  092404
I modified the BIOS to boot up from the CD drive, and inserted the Windows
XP Pro setup CD in it Version 2002, which includes SP1). I get the message,
press any key to boot from CD, and
when I do, I see the message: Setup is examining hardware, and nothing else
happens (cursor disappears). I waited about 15 minutes, and repeated the
process with no luck. Any ideas?
PS: The hardware is working fine. I have a Fedora Linux CD set and tried it,
it installed fine on this system. Obviously, I'm interested in making the XP
setup work
Solution #1
posted on Aug 09, 2005
Not Rated)
Cornish
Rank: Apprentice
Rating: 0%, 0 votes
The problem turned out to be Linux. I took the drives out, re-formatted them
under XP in another PC, and re-tried the install, and this time it installed
fine. I am however running into a different problem. Once setup is done, the
PC starts Windows OK. Next I run the setup CD that came with the motherboard.
It installs the VIA (880) chipset drivers, and at this point XP recognizes
the video card, and the LAN chipset, etc. The system reboots and instead of
seeing the Windows slapsh screen, I am now looking at a blinking cursor in
the leftmost upper corner of the screen. Soft boot / Cold boot produces the
same results.
PATA means Parallel ATA (standard IDE drives) as opposed to the new Serial
ATA drives.
Microsoft should account for a Linux formatted drive in the system and offer
to format it using NTFS (just as Linux detects NTFS drives and offers to
format using other formats).
Was this helpful?
Yes
No
Solution #2
Not Rated)
Bray
Rank: Apprentice
Rating: 0%, 0 votes
Joseph, I just went through a similar install with an ABIT NF7 and two  WD
HDD.     I'm sorry, I don't know what "P"ATA is but these were just  UDMA ATA
drives.  The master was 100 and the slave 133. (They were old leftovers) I
had the exact same symptom.  I tried a couple scenarios and ended up not
using the  slave 100 drive.  Everything went fine with just the  80 GB 133
drive.  You should also make sure your BIOS version supports 250GB, if you
haven't already.  Good luck
Was this helpful?
Yes
No
Popular Solutions for MSI PT880 Neo FSR Motherboard
Questions and Unsolved Problems for MSI PT880 Neo FSR Motherboard
Do you recommend MSI PT880 Neo FSR Motherboard?
Answer
Answer
i am having intel DG13PR mother board, now iam having front panel mic and line out connections, now... (More)
Answer
Original arcade game Space Invaders, may need new motherboard. Screen image has many vertical lines... (More)
Answer
vaio atom n270 1.6GHz no sound, limited resolutions
Answer
ecs geforce 7050 v2.0 mb has ECS geforce 7050m-m v1.0 bios 64-0100-000001-00101111-010509-ATHLON64
Answer
How do i show a video on a forum?Ive been trying to show videos on it.But the link pops up.Not the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For MSI PT880 Neo FSR Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14150
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
