Question about JVC AV-48WP30 48" Rear Projection Television
Lamp oil hdtv lamp oil where to buy it?
  • 11 more comments
  • Ego1 Nov 27, 2007
    its coolant? wow thats pretty cool thanks, would low coolant make my projection red bulb be offset??
  • Ego1 Nov 27, 2007
    no glow, my x's dont match up in converge thats what I was getting at
  • Ego1 Nov 27, 2007
    the blue and green are perfectly normal its just that the red is slanted as if it needed to be lined up with the other 2.
  • Ego1 Nov 27, 2007
    thanks for all the help, when i get home ill post my make and model and maybe you can tell me where to order the convergence Ics!
  • Ego1 Nov 27, 2007
    also how do i refill the coolant? i was stupid and drained it by accident, this is my first hdtv, I got it for $10 the picture is great except for the whole red lamp thing, but upon taking the lamp out The coolant was drained!, so now I also need to know how to refill it lol.
  • Ego1 Nov 27, 2007
    Ok I am home now, the tv is a phillips hdtv monitor
  • Ego1 Nov 27, 2007
    im home now, its a phillips hdtv monitor
  • Ego1 Nov 27, 2007
    everything came out eaisly nothing was jammed or dropped, ill try to find the correct info and chasis #, where would i find it, (on the chasis) at.
  • Ego1 Nov 27, 2007
    this is the only number set i found.
    43v BASIC
    kj02142
    3135-037-70191
  • Ego1 Nov 27, 2007
    oh here it is, the correct numbers, I apologize, dptv30 5
  • Ego1 Nov 28, 2007
    model number is 43pp92 0217
  • Ego1 Nov 28, 2007
    Awesome thanks! I live right by orlando so shipping or pick up wont be a problem thanks for all the help!!!!!!
  • Ego1 Nov 28, 2007
    thanks for all the help! appreciate it!!!!!
    Novelist:
    Champion:
  • 232 Answers
Hi, you can purchase coolant (not oil) for your tubes at
Mat Electronics www.matelectronics.com
Posted on Nov 27, 2007
  • 5 more comments
  • Larry Eastman
    Larry Eastman Nov 27, 2007
    you`ll have to give me more info than "red tube offset" if you mean the red is to the left/right of words or a person on the screen such as 2 lower case ll`s side by side and the left "l"
    is allred than that is convergence IC`s. If the image on your screen has a red fog or halo around a person or letters than that would be a coolany issue, hope this explains it for you.
  • Larry Eastman
    Ok now were getting somewhere, your coolant is fine, you have a bad convergence IC and possibly 1 or 2 bad resistors, if your not proficient with soldering & unsoldering electronic parts you`ll have to call a tv tech for this job, hope this helps
  • Larry Eastman
    I need the complete model & chassis # located on the back of the set 2 look up parts, your in trouble with the drained tube. Once you remove the fluid you can`t turn it on or the tube will fry instantly, you`ll need a tech to re-install the filled tube and get it re-aligned, I hope you didn`t re-move the yoke & lateral magnets from the tube when you pulled it from the set or the alignment is going to cost ya :(
  • Larry Eastman
    sticker on the back of the cabinet.
  • Larry Eastman
    Larry Eastman Nov 28, 2007
    DPTV305 is a Philips chassis number, I need the Model number
    and none of the other numbers you sent are model numbers.
  • Larry Eastman
    OK the convergence IC`s are part number STK392-120, you will need 2 of them and you want original SANYO IC`s so call Acme in Orlando Fl. at 1-800-575-9833 for them, I don`t know if they have tube fluid or not so you`ll have to ask, if they don`t get the fluid at mat electronics you`ll probably need 2 bottles, be advised that you will have to have a tech come in and reconverge the set when you are done, without the service manual and a good knowledge of the procedure you will never get it right but once done you`ll have a nice looking set, good luck.
  • Larry Eastman
    Well heres the address for Acme then;
    6192 edgewater drive
    Orlando, Fl.
    800-575-9833
Fan motor is macking nosie and the lamp light on front panal is flashing
Buy a new fan and replace it.Tries websites like Partstore.com,Ebay.com to buy a new fan for the replacement.Tv should be working again,if tv still have LED "LAMP" light indication still flashing.The tv projection lamp life are over.Replace the tv projection lamp too.
Apr 03, 2011 | Mitsubishi WD-65731 65" HDTV
Blinking red light that says bulb
It means your lamp is burnt out and you have to replace the lamp with a new lamp. When you install the new lamp dont touch the glass lens part at the front of lamp or the oil from your finger will burn the new lamp and it wont work.
Jan 03, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
TV is blank and powers off... lamp light is flashing
Replace lamp in tv as existing lamp is dead/ broken so tv shows lamp light flashing.
Buy Sony original replacement lamp for good picture in tv.
Aug 26, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KDS-R50XBR1 50 in. HDTV picture cycles on and off
It is clear symptoms of weak lamp in TV, replace lamp to correct that problem.
Lamp replacement is easy and written in user manual of TV.
Please buy Sony original lamp for TV safety.
Thanks.
Nov 17, 2009 | Sony KDS-R50XBR1 50" HDTV
How do i replace the bulb? How do I find the air filters?
There is a small removable door on the lower right or left hand side. It should have a screw holding it in place. Remove the door and you will see the Lamp assembly.This generally has a screw keeping it in place. Remove that screw and pull the handle attached to the lamp assembly and it will pull out.Make sure you buy a Lamp assembly that is complete with housing and not just the Lamp. You may not be comfortable swapping the new lamp into the old housing. Do not touch the Lamp with your bare hands or fingers as the oil from your skin can cause the Lamp to burn out prematurely. Take a small vacuum tip and vacuum out any dust inside the Lamp compartment before yor replace the Lamp.
Jul 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Sony KDF-E50A10 50 in. HDTV stays on for 25 - 30 minutes then shuts off by itself power stand by light flashes green and turns back on in about 20 seconds by itself. can you help?
Hi, Lamp of TV getting weaker and requires replacement. This shut off by itself will increase day by day until you put new lamp in TV. Always Buy Sony original lamp and avoid aftermarket/ cheap lamp for TV safety.
Jun 09, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
LAMP REPLACE FOR PANASONIC PT-50DL54 INSTRUCTION
Pull off the panel below the screen.
Remove the two screws hold the 2nd cover from the left.
Remove one screw from the lamp module and pull it out.
Buy the lamp module. It is not worth it to try replacing the lamp. You can damage the bulb easily.
Aug 08, 2008 | Panasonic PT-50DL54 50" Rear Projection...
Need new Jl amp
DLP LAMP SOURCE. PO BOX 503882 SAN DIEGO CA.92150
Mar 12, 2008 | Akai PT46DL10 46" HDTV-Ready Television
JVC AV-48WP30 48" Rear Projection Television Logo
95 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
