Question about GE WBSR3140DW Top Load Washer
Getting the agitator out
How do I get the agitator out of the washer
  • 6bone7 Nov 26, 2007
    I can't see where to loosen the Agitaor to lift it out and check the spline.
  • 213 Answers
There is no screw or bolt holding it in. its just a matter of getting enough upward force on it to get it out. you need to pull straight up from the bottom. some times a rope under the agitator helps.
Posted on Nov 27, 2007
Hw to get fabric unstuck from bottom of agitator on a GE Gtwn2800Doww topload washer
Some agitators at the top have a plastic lid that has a bolt under it holding the agitator in washer. Take the bolt out and agitator should come out of washer.
Aug 20, 2013 | Maytag Atlantis MAV6000 Top Load Washer
/There is a gold chain necklace wedged under the agitator. How do I loosen the agitator so it will lift up just an inch or so?
remove center downy cap on top of agitator get a 7/16 socket and long extension and hold base of agitator and loosen screw in center of agitator pull up agitator out of washer...
Jan 27, 2011 | Maytag Atlantis MAV6000 Top Load Washer
How to take off the agitator on my kenmore washer mod 11094572200
if its a older model remove cap on the vary top on the agitator it is a screw under there
Sep 28, 2009 | Kenmore 22422 Top Load Washer
Whirlpool top loader washer not agitating
Hi, Do you know if the lower half of the agitator is working? THere is a dog kit that might need replaced in the agitator to get the top half to work. If neither half agitates, there is probably a transmission issue. Start the washer with no laundry in it and see if either sections of the agitator work.
I hope this helps you.
Vic
Jul 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Feb 26, 2009 | GE WPRB9220D Top Load Washer
Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Washer will not agitate but will spin
It sounds like the plastic inside the agitator cog are worn. The smell is the plastic cog turning but the agitator not turning.
Take off the top of the agitator. If any screw are available remove them. If not grab the agitator from the bottom and yank off. Unscrew the agitator drive cog and inspect underside of agitator. Go to an appliance repair shop and reorder a new one. Between $15-30.
Mar 05, 2008 | Frigidaire GSTF1670A Front Load Washer
No agitator action
I need to get the model of the washer. (e.g. 123.123456789). This will greatly help to identify the problem and a fix for the washer. Thanks
Jul 07, 2007 | Kenmore 24032\24036 Top Load Washer
A wears out clutch might prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. Good luck!
Feb 11, 2007 | Kenmore 15864/15862 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
48 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
