Dial does not advance through all parts of the wash cycle
The cycle selector knob (on the right side of the control panel) does not advance through all parts of the wash programs. It starts, then gets stuck after a few minutes of washing; if I advance it manually by one 'click', it works for another while then gets stuck again. In a regular wash cycle I have to advance the dial two or three times for the machine to complete the full cycle.I believe my washer may need a new timer. I wanted to remove the program dial to see the whole part/assembly, but it requires taking the whole front panel off, which is a job I would rather not do until I have the spare part on hand. My washing machine was bought in Canada in 2000, it is front loading, and the model number is FWT867GHSO. It is called a 'tumble action washer' in the manual. I cannot find that particular machine on your product list, sorry.
Any help would be greatly appreciated. I now live in Panama, Central America, and this alone makes getting parts for my Canadian appliances a challenge - if I can fix it without a part, that would be excellent! If not, I will likely have to order whatever I need from North America, as most things are not available locally.
Re: Dial does not advance through all parts of the wash...
Replace the timer of the unit. With the mothel number that is behind the timer, you can order it. The timer location is at the back of the unit. Remouve the cover at the back of the control panel, then look for the part that look like a smal motor at the back of the knob. remouve the knob and the small screws, then desconect the wires plugs, do not cut any wire. then instal the new one.
Replacing the wash cycle selector knob on an Ariston AV 105 washing machine can be done with the following steps:
Turn off the washing machine and unplug it from the power source.
Locate the wash cycle selector knob on the control panel of the washing machine.
Remove the old wash cycle selector knob by pulling it straight off the control panel.
Inspect the knob shaft to ensure that it is not damaged or worn. If the shaft is damaged, it may need to be replaced before installing the new knob.
Align the new wash cycle selector knob onto the knob shaft, ensuring that it is fully seated.
Push the new knob firmly onto the knob shaft until it clicks into place.
Test the new wash cycle selector knob by turning it to different wash cycle settings to ensure that it is functioning correctly.
Once you are satisfied that the new knob is working properly, plug the washing machine back into the power source and turn it on.
If you do not have a replacement knob, you can contact Ariston or a local appliance parts supplier to obtain the correct part. Make sure to have the model number and serial number of your washing machine on hand when ordering a replacement knob to ensure that you receive the correct part.
Whirlpool manufactures many types of washing machines. Whirlpool's top
load models rely on an analog timer that controls the cycle used to wash
the clothes in the washing machine, rather than a digital control board
found in most front load models. The timer contains a number of moving
parts and is physically turned to choose the wash cycle. Because of the
high usage of the timer, it will eventually break, requiring
replacement. Rather than calling a service technician to repair the
timer, replace the timer yourself to save both time and money. Instructions 1. Unplug the washing machine from the wall outlet
2. Turn the dial to the "Off" position and then unscrew the knob from the
timer. To unscrew, hold the dial with one hand and turn the knob
counter-clockwise.
3. Lift the dial off of the washing machine.
4. Remove the two mounting screws securing the timer into position.
5. Remove the two screws from the bottom left and right sides of the control panel, then rotate the control panel up 180 degrees. 6. Remove the wire harness from the old timer and remove the old timer
7. Connect the wire harness to the new timer.
8. Place the timer into the control panel. Hold the timer post with one hand and rotate the control panel back down. Secure the timer into place using the mounting screws that were removed from the old timer 9. Place the dial back onto the timer post and then screw the knob onto the post. 10. Plug the washer back into the wall outlet
So in other words your looking to replace the knobs on your timer correct? you can order new knobs and the under side of the knob if you think that is the issue otherwise you would also have to order a new timer as well if the seating to where the dial goes into is stripped on the timer you can use this company to order any of your parts there very helpful and alot cheaper then the other companies I find http://www.allbrandonline.com/Default.aspx?Page=My%20Account%20Profile if you have any further questions or need a part number to any piece on your unit message me back the correct model number and I will look into your situation further. Also if you have any further questions message me those back as well and please remember to rank how this opinion has helped when our chat has fully concluded it allows me to continue helping others in similar situations in the future Thanks again
Rick
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
VERY IMPORTANT:
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
We have a GE WJRR4170 washer, with the same problem. At first I
thought I might have to unscrew the entire control panel just to
replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer
clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can
use a flathead screwdriver to push the clip out. The knob then will
slide easily off the metal stem. A GE replacement knob costs $9 or
$10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that
engages the dial has eight, flimsy plastic teeth. At any time, four of
these are supposed to engage four little slots in the dial. However,
the way the knob is designed, there will be a lot of wear and tear on
these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Hi. your problem is actually a rather complicated one.
Timer and selector switches
The timer switch is usually the largest dial on the main control panel. It can be either a mechanical device much like a simple clock, or completely electronic with just a digital readout.
The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
The Start switch is usually part of the timer knob. When you set the timer to the proper cycle, you either pull or push the timer knob to start the cycle.
The selector switches or knobs vary from machine to machine. Most washing machines have one or several switches or knobs on the control panel besides the Timer/Start switch. These let you adjust certain settings; for example, the water temperature, spin speed, timer cycle, and so on. Normally, the washing machine completes the cycle selected on the timer, regardless of how you set these switches and knobs.
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
