Question about Kitchen Appliances - Others
I have a Simple Human 14 oz sensor Soap Dispenser
I have a Simple Human 14 oz sensor Soap Dispenser that doesn't dispense and has a constant blinking red light. I changed the battery and added more soap. What else can I do?
    New Friend:
This is what I found in the Simplehuman FAQ's. I had to wait about 30 minutes for the light to stop blinking, but it seemed to work for me.
If the pump is unresponsive or the blue light is flashing, fresh batteries should resolve this issue. Please power off the pump completely. Once the pump is turned off, remove the old batteries. Please wait for the pump to reset (until the flashing light stops and preferably letting it rest overnight) before you install the new ones.
Posted on Oct 04, 2010
  • 3 more comments
  • sjobs99 Oct 29, 2010
    When you replace the batteries, take a look at the springs that the batteries are pressed against. One of my springs had been bent and I don't think it was making proper contact with the positive end of one of my batteries. Also make sure you press the battery plate down manually before you screw it down. This will insure that batteries make proper contact with the plate.
  • bigal4359 Feb 15, 2011
    Powering off the pump completely and then turning it back on solved my problem. Thanks a lot for the tip.
  • Corrine
    Corrine Jan 16, 2014
    Solution to blinking red light no despensing and new batteries...Turn the pump off. rinse reservoir with hot water. Use bulb end of turkey baster. Form a tight seal over reservoir and force air in. This will force the hot water thru the system and flush out the thick soap. Repeat till clear. Then turn the pump and continue to flush using sensor. Works perfectly!!!!!!!!! Make sure to thin out your dish soap in the future.
  • Montana Eury
    Montana Eury May 05, 2014
    I found a syringe that I have used for giving cats medicine. Filled it with HOT water and turned the unit upside down. I flushed the spout many times until the clog cleared and the water started flowing into the soap container. Then I ran it again, repeated the syringe action at the spout maybe 4 or 5 timed like this. Now it is working fine. There was a clog in the line.
  • D hill May 31, 2019
    I had the same problem where the red light would flash (as if battery was dead) and there was no sound of the pump trying to work. My issue was the the block plug (the part that plugs into the wall and where the cord is plugged into) was faulty. I used another plug and finally, I got a blinking blue "IM CHARGING" light! Now it works like a charm!
    New Friend:
Unfortunately, I don't have a solution. However, I have the same problem. Only my blinking light is blue. This is the second dispenser I've had with this problem. I returned the previous one to the store where I purchased it. That was less than 6 months ago and now this one seems to be disfunctional too? I believe I paid about $40+ for it. Ridiculous.
Posted on Aug 12, 2010
I am having trouble with my simplehuman electrc soap dispenser, It Is dispensing soap without me putting my hand under eye of soap dispenser. does anyone know how to fix that problem.
Posted on Sep 09, 2012
  • Jon Anderson Sep 23, 2013
    We have this same problem. The pump runs all of the time unless we turn it off. The blue light flashess all the time. We replaced batteries without success.
Had the same issue where the dispenser wouldn't light up or dispense after putting in new batteries.
The problem I had was tightening the screw to the battery cover too firmly which was apparently changing the alignment of the contacts of the cover.
Loosen the screw up a little to make sure the battery cover isn't flexing and changing the angle at which they touch the batteries. Hope that helps!
Posted on Dec 01, 2012
SOURCE:
Tip
Fix simplehuman soap dispenser
Solution!!!!! to Simplehuman sensor soap dispenser with blinking red light no despensing of soap and new batteries. Rinse out soap with hot water. Fill reservoir with hot tap water. Use bulb end of turkey baster. Place on reservoir to form a tight seal. Force air into reservoir. Which will force the hot water thru the system unclogging the thick soap. Repeat this several times till clear of soap. Then turn on the unit and flush thru the rest of the hot water using the sensor till comes out nicely. Then fill with a thinned out soap. Good luck
on Jan 16, 2014 | Simplehuman Sensor Soap Pump ST1001
How do I Install batteries in simple human soap dispenser
The hunt for batteries is over with the introduction of simplehuman's new rechargeable sensor soap pump. The newest sensor pump has a battery that recharges with a USB power adaptor, ensuring users of the product will have an "always-on" touch-free soap dispensing experience, every time. Do you have the port for the USB adapter on your unit? If so, you don't have to replace, just charge.
Aug 28, 2014 | Simplehuman Color-cap Sensor Pump by...
Blinking light
The issue is the dispensing unit you have is a sanitizer dispenser, not a soap dispenser. The adapter collar on the bottle is the issue. Soap dispensers use a GRY collar, sannitizers use an LBL collar. There should be a sticker on the dispensing unit that says "LBL" or "GRY". Try removing the collar from a sanitizer bottle and place it on your soap bottle......should work fine. In short, make sure your letter code on the bottle mathces the letter code on the dispenser.
Jan 30, 2014 | GoJo Purell 2720-12: TFX ? Touch Free...
Won't dispense soap. Changed batteries twice,
Sometime the viscosity of the soap could be the culprit. If you had changed to a thicker soap sometimes those pumps can't handle it. Try a less viscous soap and lets see what happens. Good Luck PAL
Jul 26, 2010 | NRS iTouchless Stainless Steel Automatic...
We have an Emerson hands-free soap dispenser that won't work. We've installed brand new batteries and it still won't dispense soap. The red light comes on to indicate it' s working but no soap will come...
We have 5 Emerson hands-free soap dispensers that don't work. Tried new batteries, light comes on, but no soap comes out. How can we get our money back?
May 20, 2010 | Vacuums
My simple human sensor Soap Dispensor will not
Hi, you have this question in the wrong park of the site. But I did a quick google search and believe I may have found an answer for you. I'll copy and past what I found for you here. If this doesn't solve the issue you should probably repost this question
"In the spot where the soap dispenses, there is a very small plug which controls the flow which you need to gently pull out and release (not break off) in order to break the vacuum seal. This information is not included in the regular instructions, but rather is written on a small 2-inch square piece of paper in the box. I was getting very frustrated because I had "primed" the soap dispenser at least 30 times and nothing had come out. I noticed the small plug, and while looking through the box again found the small piece of paper with the additional instruction. After that, it worked great! I use a generic version of Soft Soap, and we find the lowest setting dispenses more than enough soap."
Mar 04, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
Soap drawer on bottom washer won't open
Hi and welcome to FixYa.
That cup is held closed by a simple clip that is molded into the dispenser. There is nothing that would really keep it closed unless it is physically broken. Without being there to see the situation it is is hard to offer up anything else. I can say that if the cup is broken, that dispenser is a part #526860. It is not hard to change at all, you can do it yourself and you can order one here:
http://fisherpaykelparts.net/index.php?categoryid=113&productid=19
Hope this helps.
Dec 28, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Kitchen Appliances - Others Logo
27,405 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Irene Tulloch
john h
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
