Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Problem for Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
After the normal delay period, my heater ignites
By muscanay on Aug 05, 2009
after the normal delay period, my heater ignites as normal,but after anywhere from 10 to 30 seconds the flame shuts down. Could this be a bad flame sensor rod?
Best Solution
posted on Aug 05, 2009
Very Helpful)
1STHVACMAN
Rank: Guru
Rating: 91%, 24 votes
flame sensor rod is probably not bad but just has a soot build up on it. take some steel wool or I use a soft brass brush and make the rod shine. DO NOT USE ANYTHING COARSE, if you scratch the rod it will rust, then it is bad
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Lite On Laars Lite 2 Heaters:
Questions and Unsolved Problems for Lite On Laars Lite 2 Heaters:
Do you recommend Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater?
Answer
Answer
have a problem with a laars boiler the pilot keeps going out. the thermostats only work on max as... (More)
Answer
laars lite 2 pool heater heats and then stops I checked the temp sensor and it is fine. Is this the... (More)
Answer
I am winterizing my Laars Lite2 pool heater and have what may seem to be easy questions but... What... (More)
Answer
I have a Laars LX400 heater. Yesterday the heater would not start - Hi Lim SW error. I replaced... (More)
Answer
Won't light see a flame and hear it try to kick will come on briefly and then go out.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Lite On Laars Lite 2 Heaters:...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
