Question about Weather King 12AJA6001AH Air Conditioner
Thermostat hookup my thermostat has 4 wires red,while,yellow & green hooked up to it,but the wires to the unit were removed & I dont know how to reinstall can you please e-mail me a dieogram of how they go hooked up please thank you very!
  • fedele Jul 08, 2008
    wire for honeywell thermostat white red green and light blue,
  • 1,420 Answers
There will be none commercially available. You need to use the diagram that came with the thermostat and the diagram on the access panel of the furnace. Typically Red goes to R, Green goes to G and so forth. Red and White are your heat cycle wires. Red and Yellow are your cooling and the Green is to operate the blower. If only 4 wires, you need a jumper at the thermostat going from R1 to R2. Check the connections at the furnace to make sure they are attached the typical way prior to attaching them to the thermostat.
Posted on Nov 27, 2007
I have a bryant model 702b packaged unit with 5 wire thermostat wiring coming out of the unit. R Y B G and W. The thermostate in the house is 5 wire and goes to the old central unit and them has a 4 ire...
R-Red is power
Y-Yellow is cool
B-Blue is cool as well
G-Green is fan leg
W-White is usually heat Leg
If you have no indoor unit and this is a ac/gas or
electric outdoor unit try this.
R to R/Red to Red
G-G/Green to Green
Y-Y/Yellow to Yellow
W-W/White to White
-Dont Hook up Blue.
Turn power back on turn the fan to on,fan should run
Turn to Heating, heating should come on
Turn on Cooling,if cooling does not come on switch yellow with blue.
Jul 02, 2010 | Heating & Cooling
All my wires or off on the unit thats in side my house its 4 wires that hook up to the blower
Check the wiring on your thermostat. It should go something like the following.
RED to RED
WHITE to WHITE
GREEN TO GREEN
YELLOW to YELLOW
The 4 wire that we sell has red, white, blue, and green so our contractors wire it up by going blue to yellow.
Jun 05, 2010 | Heating & Cooling
Replacing thermostat what to do with single red wirew/bridge?
yes u leave the bridge intact and just put ur red wire to r or rc and usually they say rh and rc that is for a 2 transformer system which obviously u dont have so leave the wire intact jumped and hook ur red wire up yellow is ur ac wire white is ur heat wire and green is ur fan wire and red is ur 24 volt hot wire all a tstat does is jump that red wire to white for heat green for fan or yellow for ac but make sure ur power to ur unit is off before u change wires or u risk touching wires together and burning up transformer
Feb 24, 2010 | Honeywell Programmable Thermostat Heater
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
I have a coleman Evcon model AH16-0 . I am
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 06, 2010 | Heating & Cooling
Trying to figure out thermostat wiring diagham on a split system
4 Wire Termostat
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
W = White Heat
Jan 05, 2010 | Heating & Cooling
I have a coleman evcon gas furnace I want to change the termostat to a programmable thermostat I don't know where the wires hookup we have four wires red,white,yellow,green. I have a honeywell RTH230b...
The thermostat has terminals which are marked for color, R = red, W = white, Y =yellow, G =green. There should be a jumper between Rh and Rc, Hook the red to Rh.
Jan 01, 2010 | Coleman Propane Forced Air Heater...
I need wiring manual for goodman mini split.
outside unit L1 and L2 are load (input 240vac)
then you have control voltage, usually yellow and blue (24vac) this connects to some 18/2 thermostat wire which goes inside as white and red.
note: this unit may only need 24v control which is 2 wires from the inside unit and also 3 wires 2 hot 1 ground for line voltage.
STANDARD WIRING
on the inside unit you have green, white, blue and red control wires.
on your thermostat you have white, red, yellow and green
you run the wire from the outside unit to the inside unit. then run a 18/4 wire to the thermostat if wired and join the following wires.
inside unit thermostat outside unit
green------------------------green
white-------------------------white
red----------------------------red
blue-------------------------------------------------------blue
yellow--------------------yellow
Oct 08, 2009 | Heating & Cooling
I have a mobile home with just heat but the air cond come with it
You will now need a 4-wire thermostat as well as 4-wire thermostat cable since you now have cooling in addition to heating. The 4-wire cable should have a red, green, white, and yellow wire. Some cables have a blue wire in place of the yellow wire. The red wire, which is 24 volts hot, goes on 'R' terminal. The green wire, used for the indoor fan, goes under 'G' terminal. The white wire, used for heating, goes under 'W' terminal. And the yellow or blue wire, used for cooling, goes under 'Y' terminal.
Aug 05, 2009 | Heating & Cooling
What is the blue hooked up to now?
Jun 07, 2008 | Honeywell Electronic Programmable...
Weather King 12AJA6001AH Air Conditioner Logo
305 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
