Question about Panasonic KV-S2026C Pass-Through Scanner
Problems when scanning
We have a scanning application and at one installation we are seeing several problems with scanning. We have 5 scanners running at this installation, and are seeing various problems on different scanners. We have not userd the 2026C before, but have used the 2025c. We are not sure if these problems indicate a problem with the scanner or a user problem.
There are three problems.
1. The scanner often takes up to 8 secs before it starts scanning if it has not been in use for a few minutes
2. There are tracks and lines appearing on some of the forms that get scanned. These marks appear as straight lines runing vertically down the page. They appear in the same place on forms from two different scanners.
3. Some of the scanners appear to consistently pull the forms through askew, without any indication in the paper flow. It's as if the scanning bar inside (if there is such an animal) is askew.
I am aware that site is using NCR forms which I have previously been told is a MAJOR NO NO for scanners. I am thinking this could be part of the problem.
The application that is driving the scanner is a VB app using scanning drivers put out by UniSoft Imaging.
What are your opinions, suggestions etc.
  • 324 Answers
Re: problems when scanning
Good evening ksys,
Let me address these and see if I can be of some help.
1.Many scanners will go into a sleep mode, in an effort to conserve power. I don't know for sure but this maybe an option that can be reset somewhere in the control panel menu. Refer to your user guide in the sections that talk about energy, sleep mode or conservation.
2. The tracks that you see on the printed forms sound like a problem in the photo conductor area. Toner beads (or lint, paper shreds, etc.) will clump up and cause this to happen. If you can get to the photo conductor, a gentle cleaning (usually in the area where the photo conductor is pulled back down into the toner bin) may resolve your problem. In some cases, you may actually see a band or streak of toner on the photo conductor. These can sometime be removed, but if the photo conductor is scratched in that area, the problem will come right back. Any cleaning in this area needs to be done with a very soft, clean, dry cloth. You have to be careful not to scratch the photo conductor, or you will just add to the problem.
3. Yes the skewing problem can definitely be caused by the forms. And NCR paper has always seemed to present problems in printers and scanners. Some machines can be adjusted (usually out of specs) for correction of this problem, but many cannot. Something else that you may look for is any type of buildup on the feed rolls that move the paper into, and through, the machine. Any deposits found on the rollers can usually be cleaned off with 90% rubbing alcohol and a cotton swab. If the deposits are dark in color, they could be part of the cause of the verticle streaks that you mentioned. I would have to actually look at the machine(s) in question to determine whether or not this could be done.
Hopefully, this information will be of help and what you were looking for.
f you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Posted on Nov 26, 2007
0 characters
3 Points
Trouble scanning a document as a .pdf file
You need to have a pdf-handling application installed on your computer. At least you should have Acrobat Reader. There are several pdf handling applications on the web. Google pdf. (pdf Architect, pdfTK, pdfBulider etc.)
Jan 09, 2014 | Canon CanoScan 8600F Flatbed Scanner
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Jun 22, 2012 | Scanners
Hi, HP Scanjet 2200c (Scanner) does it work for windows 7?
Hi dorine...
HP Scanjet 2200c drivers (xp/vista/win7/win8/mac) can be found at driverupdate us It will take 2 mins from you to install...
I hope I have helped you...
Oct 07, 2009 | HP ScanJet 2200C Flatbed Scanner
Installed driver twice for Canon DR-2050c. Still
Pls run checkdisc/scandisk on your Comp. Your OS may be corrupted. Just to verify try scanning by connecting to a formatted newly loaded OS Computer.
S. Mohan
Sep 09, 2009 | Canon DR-2580C Path-Through Scanner
Stopped at start-up after months of no problems
Please trash the twain driver completely.
- Trash epson scan and epson scanner monitor from applications.
- Go to hd. Go to library, then application support. Trash epson scanner module.
- Go back to library. Click on image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on your computer name. Click on Library. Click on preferences. Click on the epson folder. Trash epson scan.
- Empty the trash and restart your mac.
Log on to Install the epson11926.dmg.
Apr 28, 2009 | Epson Expression 1640XL Flatbed Scanner
Fi=5120c conflict with another scanner
Kindly reply back immediately once you get my email.
Nov 04, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
DR-9080C intermittent stops during scanning which last 3 to 5 minutes
Do you have enough hard disk space? Reinstall your driver software. Run Scandisk on the Comp.
Is the problem coming on after a set time interval, any heating smell?
S. Mohan
Jun 22, 2008 | Canon DR-9080C Path-Through Scanner
Random black lines on scanned slides
Normally dark lines are a speck of dirt sticking on to the glass and when scanned continuously, it appears as a line. Clean the glass thoroughly. Ensure the slides are dust free. If the lines are appearing in different locations, it means the dust gets removed while scanning. Line in the same place could be because of glass is scratched. The above is common with roller scanners.
For fat bed scanners, there will be no scratch on the glass. It must be from the slides/documents
Feb 20, 2008 | Braun MULTIMAG SlideScan 4000
Film holder problem
try this
Turn on the scaner (diode is blinking), then run aplication DS Dual3
After start application you sould hear the transport mechanism test.
The green diode should light permanently (important).
Push deeper the holder.
Jan 29, 2008 | Minolta Dimage Scan Dual III Film Scanner
Panasonic KV-S2026C Pass-Through Scanner Logo
342 people viewed this question
Top Panasonic Scanners Experts
Abhinandan  Patil
Abhinandan Patil
Bob Sloan
Are you a Panasonic Scanner Expert? Answer questions, earn points and help others
