This doll was given to me. I noticed it wasn't working and thought it was in need of fresh batteries. I removed the covers from both feet and found the batteries were leaking. Hi cleaned the area, removed all particles from battery and replaced with new ones. No luck! I am determined to fix it if I can. Don't know where to look for year of doll. Thank you.
SOURCE: help! thought battery was dead but...
try a master reset and clear all data on the phone......if that does not work have the phone's firmware reflash by taking it to a professional mobile store and getting it done there.
that should fixed you issues with the phone :)
SOURCE: Thermostat not working
Chances are that the fuse in the furnace blew. Remove the inspection cover on the furnace and look for a 3 amp fuse either in-line of the wiring or on the control board. Also check the circuit breaker box.
SOURCE: instructions for 1987 mattel baby heather interactive doll
hi i have a baby heather and she works fine ,
hope this is some help ,
look at the back of heather
you will see two battery compartments the large1.5v box and above that a button stating grow up
press this once ist stage baby
press again goes to 1 year old
press again goes to final stage two year old
directly below the large battery compartment
two rubber buttons
one grey one red
red means enter the programme mode
the time she first says is the time set to work on
push the grey button to change hour keep doing this till you get the desired hour to match our time
press red enter button
does this quite quickly or she will say exiting program mode
heather then instructs you
on to morning wake up time
press the grey button to enter wake up time keep doing this untill you get desired wake up time
heather now knows her wake up time
press red button again for night time sleeping mode ,and follow the same steps as above till you want her sleeping time press red enter her sleep time is stored
if you press the red button again she tells you her developement status , baby 1year old or two years old , confused yet i hope this is clearer than it types
ok other functions
below her aa battery box the small thin batterys there is a switch
to the left it says off eyes closed
when switched to this the doll will switch off with her eyes closed
when switch is in the middle she s on and ready to play
when switched to off eyes open heather is switched off but her eyes remain open
still havent understood the clear round button but give me time
under her left arm if she is facing her away from you is her ticklish spot she likes that sometimes if she doesnt she will soon let you know ,
below her tummy is another sensor this is her hug sensor so if she asks for a hug gently push her tummy and she will know , heather can hear you and she will look around to hear your voice her eyes move left and right and her head turns as she working out where you are
also peek aboo if you d like to play, gently place your hand over her eyes she will respond ,
also horsey if she wants to play gently bounce her up and down and be careful these dolls can suffer from loose or detached legs ,
other tips if she doesnt have an original outfit pick one that wont restrict head movements , as for feeding , or hair brushing im working out if she does need original items or another doll item will do
have fun
russell
SOURCE: model 950 respironics oximeter stopped working
Here is the manual for your device http://global.respironics.com/ServiceManuals/Service950Oximeter.pdf
The troubleshooting guide does recomend making sure you have the batteries postitioned correctly. Also if the battery did leak into the unit it might have ruined it, I would really suggest getting a new unit to ensure acuracy it is sensative equipment and it sounds like the unit may have been comprimised.
SOURCE: Battery cover replacement
First, replacement battery covers may be obtained from dealers in the USA - I got mine from San Diego Camera Solution who list the item on eBay. Haven't found a UK outlet, but I guess Leung's at Goodmayes would offer a repair service if you don't fancy DIY.
(Disclaimer that I have no connection with either company).
Not sure what Canon recommend, but the easiet way (worked for me) does not involve stripping the camera down. If you dissemble the old and new battery covers via the three little cross-point screws (see warning), then it is possible to replace the new cover around the original hinge assembly.
The advantage of this method - aside from not opening the camera - is that there are "spares" the bits that will get dropped (spring and screws) so that there is less time wasted trying to find them while effecting the repair!
The trickiest part is the sprung loaded latch, which must be installed with the spring partly compressed. Beware when first taking the covers apart and especially when refitting, because the spring will do its utmost to escape.
