SOURCE: Blinking power button
You likely have bad convergence output IC's that have caused one of the supply fuses to blow. This repair will have to be performed by a qualified technician. If you were in our area and has us repair this the total cost of the repair would be about $340 if I am correct about the cause of your problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
SOURCE: No Power to my TV after power outage
Last night, my Panasonic television went off due to a partial electrical power outage that affected my house. After the power was restored, the TV would not come on. The electrical outlet being used is good. I was looking at the parts list for the TV at Panasonic website and saw a fuse (6.3A-125V) listed. Maybe an electrical surge last night burnt this internal fuse out and that is the only thing I will need to replace. I wonder if this was the fuse that Leen14 was referring to in the original post that checked out good. Any additional information will be greatly appreciated!
SOURCE: ILO 2706 TV WONT TURN ON
This TV might have been affected by the power outage even if it was not ON at that moment. There is a standby voltage still present even when OFF and connected to the AC line.
There might be different failures on this TV:
1. The power supply might be defective after the power outage.
2. The main board could also be defective since the power supplies for today's TVs are not well regulated and once the voltage getting to the power supply increases, the standby voltage voltage will also increase damaging voltage sensitive components like the microprocessor or memory circuitry.
Let me know if you require further assistance.
SOURCE: sound cut off every 10 minutes
Turned up volume on receiver and turned down volume on the headset......no more problem. Thanks to the person who posted that solution on the web site.
SOURCE: I had a power outage. After power was restored
Replace the adaptive defrost control part number 240375803. About $100.00.
It is located in the fresh food section on the top left side behind the plastic panel.
