Question about HP LaserJet 2840 All-In-One Printer
Toner refill kits for hp 2840
I have been using toner refill for my hp 2840. Everything was fine for about a month. Then only the right side of the page was printing.
After speaking with hp...they sent someone hear & said the carriage is misaligned. The tech took the printer & came back later with the problem fixed. After printing a couple of good pages...it started again printing on the right side only.
Now the hp tech says this problem is caused by refilling the cartridges & I should buy 4 new cartridges & have the carriage aligned again.
Before I go & spend the $$, I thought I would ask if anyone knows about this.
The printer is only about 6 months old & this is the first refill.
Thanks!
Shelley
  • hpproblems Jan 02, 2008
    Installed all new cartridges and only prints on right side of page
  • robertinski Feb 17, 2008
    I installed remanufactured yellow, magenta and cyan cartridges at the same time and, although i was printing black text just fine before the change, afterwards all four colors are printing on the right side only...fading to a faint print in the middle and nothing nothing left of center.....has anyone come up with anything? can this be a carousel alignment problem even though all four colors appear as they should when i rotate cartridges on the main panel? if it isn't a carousel alignment problem, what else could it possibly be? i have a service manual and the mechanical know-how to take it apart if necessary but that will be a last resort.....
I have the same problem. Happended under warentee and the HP techs have replaced about everything but the printer's shell. They fix one thing and break another, but refuse to replace the printer and we are going on 5-6 service calls.
It all started when I replaced the magenta toner. BTW the HP techs constantly lie about what they did and when they will be back.
Posted on Feb 11, 2008
Which one refill kit I need on this page?
HP Easy Refill Kit for (HP) Color Inkjet Cartridges Printer
Jul 10, 2012 | HP Easy Refill Kit for (HP) Color Inkjet...
How to reset supplies on HP 2840 laserjet?
"Would like report of supplies from 2840 laserjet. How to get it to show report"
Select 'Menu" button, then select "Reports", then select "Supplies Report".
This will print the status of the four toner cartridges and the drum.
It doesn't make sense to reset toner cartridges UNLESS you refill them
first. On the HP 2840 each cartridge/drum contains a chip that measures
the life of the unit.
You can purchase toner/chip combinations online cheaper than new
cartridges. I also purchase drum chips to extend the use of my drum
until print quality actually starts to deteriorate.
I use both of these methods to save money on supplies - buy toner and
toner chips, buy drum chip to get full use of drum unit.
Hope this helps.
Mar 19, 2012 | HP LaserJet 2840 Printer
Hp laserjet 1100 toner catridge refill?
Hi follow these steps..
1.Purchase a refill kit for your model of printer. It is important to purchase a refill kit designed for your specific model, since generic refill kits do not work well with HP printers. There are a number of places to buy these kits, but you must make sure you get the right kit for your printer model
2.Take the toner out of the printer and clean it carefully. Over time toner cartridges will accumulate paper dust, dried toner and other debris, and all of this must be cleaned away before the cartridge is refilled.
3.Flip the cover out of the way to expose the developer roller, then use a soft clean cloth to clean the roller. It is important to clean this roller before refilling the cartridge.
4.Make a small hole in the toner cartridge, using the instructions provided in the refill kit. It is important to follow the refill kit instructions carefully, since the toner refill process will vary from model to model.
5.Place the replacement toner in the hopper, then carefully pour it into the HP cartridge. Be careful not to spill any of the toner, and if you do spill the toner be sure to clean it up promptly. Reseal the hole you made after the cartridge has been refilled.
6.Sit the refilled HP cartridge on a clean flat surface and let it remain there for 20-30 minutes. Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
7.Pick up the cartridge and make sure no toner has leaked out. If you do see any leaks you will need to reseal the hole you made again.
Good Luck & cheers:-)
Jun 30, 2010 | HP LaserJet 1100 Printer
HP Laserjet 2840 asked for drum replacment afther only 5300 pages but should make 20000. Prits where still perfect but now it refuses to print. Any solutions how to keep using the drum?
Check online for refill instructions and where to buy the chip to replace on the drum, most of the drums today have little chips to replace that tell the printer when they are used up, even when there's still life in them.
Dec 24, 2009 | HP LaserJet 2840 Printer
I have an HP color laserjet 2840 and just replace the drum not long ago, maybe back in the spring, and changed all the colour cartridges in the summer, now it's saying to replace the drum again, the...
The HP Color Laserjet 2840 Is a Very Good Reliable Printer. I'm curious if you are buying American made components or cheap components from some thrid world country sold at ahuge retailer. They really should stand behind their laser drums, but if they don't then shop over at www.officeinks.com or www.wowsuperdeal.com and Purchase American Made Toner Cartridges and Laser Drums. Office Inks has a 1 year satisfaction and quality guarantee and free return shipping if their ink, toner, drums, ribbons etc, don't make you happy. Only Ships USA Though.
Oct 15, 2009 | HP LaserJet 2840 All-In-One Printer
How to change the drum in the HP Printer 2840
romve the toner and right side scriw and left side scrue the remove in toner and remove the drum ......
insert the new drum if any probelm logon www.compudesk.in and click live chat and send off line msg .
Oct 12, 2009 | HP LaserJet 2840 All-In-One Printer
HP 2840, black ink drum q3964a
Hello, these printers tend to be finicky.
In other words, just replace the black toner. When the printer says its low, or empty, regardless of wether or not it is, just replace it.
Replacing the drum, when it says black toner needs to be replaced will do nothing to rectify the issue.
Buy only HP Toner and Drum cartridges for this printer. Do not try to refill toner cartridges, and do not reset drum. You will only end up destroying your printer in the process.
Feb 26, 2009 | HP LaserJet 2840 All-In-One Printer
HP Color Laserjet 2840 refill problem
It may be that the cartridges are the problem? Usual fix is to go back to before the problem and start again. If you don't have old good cartridges, you may have to get new cartridges.
Feb 15, 2009 | HP Color LaserJet 2550n printer + HP Color...
Refill problems pages are stained
Original refills are best rather than using refill kits, but are expensive and produces clean results... Well, that's the way it is, I too got refills and I expected it to have unwanted results.
Use it until emptied and buy original refills to get best results.
Let this be a lesson us... After all, it's a part of learning via our mistakes.
Jan 31, 2008 | HP DeskJet 5550 InkJet Printer
HP LaserJet 2840 All-In-One Printer Logo
117 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
