I have a kodak easyshare cx6230 and bought a memory card for it when i put the card in the camera it says memory card requires formatting and i press continue it starts to say formatting and then says memory card requires formatting but does nothing. Can anyone please help.
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
It's just gonna loop if you're using a card more than 1GB. This particular model will only work for 1GB or lower SD/MMC card.
