I've already tried a lot of solutions
SOURCE: Sony DSC P52 won't flash Error Code is E:91:01 tried reset already
When you pressed the reset, if it cleared the time and date that button is working. If that did not clear the error it is a hardware fault, meaning that a circuit has failed and parts will have to be replaced.
A local camera store might be able to find the problem but you will have to carefully weigh whether these older camera is worth the cost of repair.
Sorry! I hate giving bad news.
SOURCE: error code L1
There is lock located on the bottom of the scanner on the left side. Make sure the knob is in the unlock position. If it is, then there is plan B I can tell you about.
SOURCE: Error Code 8e5e0408
the only thing that I found the fastes solution is to update your msn by doing so many issues will be solve, it will take few min to downloud..
your rating is very important to me ....
Was this helpful?
SOURCE: i've tried already all the solution that you
format operation
you have to download nemesis service tool program from internet to your PC
and read the instructions
then connect your mobile phone with the PC via usb cable or box cable and continue
SOURCE: Error Code #380
I had the same problem and decided to try a long shot, I opened the front cover and saw there is a sensor there black plastic which tips as the paper passes. I added a very small blob of bluetack onto the counter balance, printer now working.
