Have replaced Outlet Thermistor, inlet thermistor/high limit thermostat, Machine Control Electronics & Power cube. Airflow fine. thermistor resistances within specified ranges. I'm baffled! Any suggestions?
SOURCE: My dryer won'y blow hot air
Bob, I did not lie, I just checked the heating element orginally with an Olm meter while the element was still installed in the dryer. After more reading on the internet and testing I decide to remove the heating element and noticed it had the short.
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
SOURCE: i have a kenmore he4 no. 110.85871400. i have no
Check thermistor with ohm meter, make sure you unplug unit first, make sure wires are removed from thermistor or you will read ohms thru the wiring. If thermistor checks ok, the you have a relay board problem. replace power board.
SOURCE: whirlpool GEW9200L not heating up, i have replaced
not being sarcastic, but, your sure you have 240 volts present at the unit? then check door switch heat section control of switch may be bad
