Question about Brother IntelliFAX 2800 Laser Fax
2800 fax Hi,I have been given a 2800 fax machine with out a manual to use for work purposes. Does this machine have designated ring feature so that i can get away wityh out a second line being put in ?I can't seem to find a on line manual, any suggestions?Steve
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,362 Answers
Posted on Nov 27, 2007
Brother intellfax 2800
Scroll through the menus for NUMBER OF RINGS
Oct 20, 2008 | Brother IntelliFAX 2800 Laser Fax
Given that the last question I responded to for you related to a Fax JX200 - and this to a JX500 - I am not certain which model you are actually asking about. The information that follows relates to the JX500. Further, if you need information in this regard on the prior post in order to feel that the previous response was a FixYa level response, please let me know. I responded based on the information you provided...
Based on the fact that you are getting a constant 5-ring situation, it appears that the machine is in TAM (tel-ans mach) mode. The purpose of 5 falls into remote recovery of messages - toll saver results in the phone answering after 2 rings if there are messages to retrieve, and 5 if there are not. This is done to prevent long-distance charges if there are no messages.
Two ways to accomplish an 8-9 ring objective. (1) Place the machine in manual mode, which means answering every call and sending faxes to the machine. Additionally, a "fail-safe" on this mode is that it will switch to TAM/automatically answer (if there is a recorded greeting message) after 15 rings - below. (2) The incoming ring - ring count - can be set (under Fax/Tel Auto) to ring 10 to 60 seconds before the fax picks up. (3) Alternatively, the Incoming Ring ring count can be set to have the fax ring 2 to 30 times, depending on the country specific parameters.
Re TAM: When the fax is set to <MANUAL MODE> and <MAN/AUTO SWITCH> has been set to <OFF>, TAM MODE will be activated if the fax rings 15 times and the call is not answered (only when an outgoing message has been recorded). When the call is disconnected, the fax returns to <MANUAL MODE>.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding your specific needs, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 04, 2008 | Canon FAX-JX200
Yes, just set the receive mode to "manual" the machine will then just ring when a fax is incoming and not print. It may become annoying after a while because the sending machine will try to send numerous times. You can get around this by setting the ring volume to mute.
Jun 06, 2008 | Brother IntelliFAX 2800 Laser Fax
Setting personalized ring
Its called distintive Ring. This is the instructions from the manual -
If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
one of your phone numbers dedicated only to fax calls, you must leave the fax machine
in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
answer calls for all the numbers.
Registering the Distinctive Ring Pattern
Set the fax machine to MANUAL mode.
2 Press Menu/Set, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
Be sure to choose the pattern assigned by the Telephone Company.
5 Press Stop/Exit.
and a link to the manual if you need it -
Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Audible ring has changed/machine won't answer when called
It is to do with "smart ring" feature or in your area called "distinctive ring" feature. The machine won't receive unless the ring pattern matches your distinctive ring pattern. If you are not using that feature, then you must turn the feature off. Then set your receive mode to "fax tel" mode if it is your only line.
Jan 16, 2008 | Brother IntelliFAX 2800 Laser Fax
Incoming fax
Do you have the manual? Check your smart ring feature.
Sep 05, 2007 | Brother IntelliFAX 2800 Laser Fax
Smart ring
Good question. I thinking your service provider (Bellsouth, Western Bell, etc..) might know this. I'm sure they have run across this before. I know that your fax machine will need to support this feature. For example, Brother Fax machines have a Distinctive Ring function on them for just this purpose. Do you have your use manual for your fax machine? It should tell you if it supports Distinctive Ring.
Jun 25, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
110 people viewed this question
James Cagle
James Cagle
Jim Keysor
