Question about Bosch Washing Machines
Why can’t I use fabric softener in my brand new Bosch front loading washing machine?
SOURCE:
SOURCE: Kenmore Front Loading machine, does not drain the fabric softener
We had the exact same situation with the fabric softener not draining and here is how we fixed it. Turn the water off first, then remove the water lines that bring water into your washer. (They are near the top.) There is a screen in the end of the line, do not remove it, but take an old toothbrush and brush the gunk out and clean it as best you can. Do both the hot & cold sides. The screens keep any debris out of the washer, so after a while it collects and slows down the water intake time (has your washer been slow to fill also?) Screw back the lines, making sure to put the hot and cold back as they were originally, then test that they do not leak. Put your washer back in place and viola - problem solved! I hope this works for you, and good luck!
Posted on Oct 28, 2006
barkencoa
  • 3463 Answers
SOURCE: Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Posted on Nov 25, 2008
localwonder
  • 6784 Answers
SOURCE: front load washer
HI. your model has a dispenser solenoid for the fabric softener dispenser on this unit. If the solenoids are out or malfunctioning, it will render the dispenser useless. i recommend checking the solenoids on the fabric softener dispenser for continuity. The resistance should be 1100+- 7%. replacing this blown solenoid will fix this issue. Remember. the dispenser valve will not function without a working solenoid.
please rate and god bless.
Posted on Mar 22, 2009
lmwp
SOURCE: Fabric softener dispenser does not empty on Bosch
I have a bosh washing machine and the fabric dispencer was not emptying, i took the compartment out and washed it all out making sure all the muck was off. Then i looked in the machine (where the dispencer had been) and looked up. There were some holes so i got a needle and poked it up and wiggled it, some black muck came out, i cleaned the rest of the holes and now it is working again.
Posted on Mar 24, 2009
SOURCE: Hard scratchy towels. Have used all wash cycles, and use fabric softener
have you tried just white vinegar as your rinse aid. Do a full cycle of your washing machine using white vinegar instead of detergent, to clean any residue from pipes, and then in the next wash try white vinegar as your rinse aid.
Posted on Apr 18, 2009
Front load washer dispenses fabric softener drawer fills water
either the auto dispenser is sticking , take out and clean with hot water. Or flow control valve needs replacing.
Feb 24, 2014 | Bosch Washing Machines
My Bosch washing machine doesn't add the softener from its compartment
The first thing you should do is check the compartment from the fabric softener. If something is blocking the exit of the softener, the machine will not add it.
If you checked the exit or the holes in the valve of the fabric softener compartment and nothing seems to be stuck there, there could be a problem with your washer's timer. Check the timer and get a replacement for it.
source: http://www.washingmachineadvisor.com
Jul 18, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Sep 14, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Fabric Softener Dispenser wont drain
Try using a long handled babies bottle brush to clean out the rear of the dispenser and the tube leading down into the drum
Jun 18, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Apr 18, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Bosch Nexxt series washer - water in softener dispenser
Hi. Remove dispenser, and thouroughly clean.
This should solve problem. If problem persists, don't worry about it tomuch, as long as it takes the conditioner down that is the main thing.
Nov 23, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washing instructions
My book says for the Axxis WFL 2050/WFL 2060 : from the left while looking at it from the front: detergent for wash, stain remover, middle: fabric softener, fabric conditioner, right one: detergent for soaking agent. (Do not use chlorice bleach in this wasking machine).
Oct 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
62 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
