Question about Roland GX-300 CAMM-1 Pro Vinyl Cutter
Roland Camm-1 Pro is giving Motor Error 2 in the middle of cutting. What does this error mean and how do i remedy it? All the wires are connected securely between cutter and computer.
SOURCE:
marked
  • 6487 Answers
SOURCE: Roland Camm-1 CX-24 Error Er15:RS-232Err How
Where and when do you see this error? and what operating system are you using?
Posted on Aug 02, 2008
SOURCE: I have a Roland Camm-1
connect the printer and the comp. and boot up....windows should recognize the new device.
did you add the plotter to "add printers" and its driver and to the correct port?
make sure your plotter is on and loaded and function key pressed.
also some cable manufacturers supply a driver...so download one if need be.
what software are you using? is the software cutter driver set to the correct printer and port?
(by default it never is)!!
Posted on Apr 16, 2009
maxtreadmill
  • 832 Answers
SOURCE: asi image pro 2 treadmill error code 2
Loss signal or No Speed: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt2_bing.gif now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
Posted on May 15, 2010
SOURCE: all four colors wont print roland sp300v
you print head is dry out. Normally, it happened on Magenta and Cyan colors.
Posted on Jun 15, 2010
  • 1140 Answers
SOURCE: Roland e09 read "midi error" when connected with
If you have the version 1 cable you need to download a driver. The details are at this link:http://www.cme-pro.com/en/news-detail.php?news_id=105
Posted on Nov 09, 2010
Fault motor voltage error
Check the voltage. You may have to do a hookup. (hookup) a unique connection to a component to check voltage or signals.
May 09, 2014 | Roland GX-300 CAMM-1 Pro Vinyl Cutter
Roland Camm-1 CX-24 Error Er15:RS-232Err How do I fix this? Thanks John
Could you let us know when this error pops up. and what all you have tried
Thanks
proton
Aug 02, 2008 | Computers & Internet
Roland drivers
ask them ,,, i think you use the adobe software provided ,
Mar 29, 2014 | Computers & Internet
Pen mode light blinking
Material not aligned or wrong thickness... Blinking means something is not right. Try taking the material out and see if it changes, things like that, troubleshooting....
Nov 26, 2013 | Roland GX-300 CAMM-1 Pro Vinyl Cutter
Message error moteur (02) sur camm 1 GX 300
XEROX 5020 PHOTOCOPIEUSE ERREUR U4 LA SOLUTION
Sep 16, 2012 | Roland GX-300 CAMM-1 Pro Vinyl Cutter
How to get out of dpics mode on a roland camm-1 pro gx400
Please help us the error code comes "dpics mode" in roland gx-500
Jul 29, 2012 | Roland GX-400 CAMM-1 Pro Vinyl Cutter
I have a Roland Camm-1 CX-24 cutting machine that has a parallel connection. I have recently bought a Dell Inspiron 1720 with a Windows Vista OS. I have a USB to Parallel cable to connect the two. I have...
Aug 03, 2008 | Computers & Internet
Roland GX-300 CAMM-1 Pro Vinyl Cutter Logo
71 people viewed this question
Top Roland Office Equipment & Supplies Experts
JonSnell Electronic
JonSnell Electronic
Ravi
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
