Question about Kole audio QX1-2400D Car Audio Amplifier
Protect light will not turn off!?
All connections are good to the amp and have been checked several times with a meter. The porect light won't turn off and just turn to green?
  • Anonymous Mar 11, 2009
    protect light won't go off
  • 631 Answers
In most cases when the protect light is lit, the amplifier's output transistors have failed.
If the amplifier goes into protect with no speaker wires connected to it, it's likely in need of repair.
Posted on Nov 26, 2007
My soundstream vir 7200 won,t turn on. no visable fuses blown. how and where is reset button and is there a fuse behind the radio.
the reset button is on the bottom left side of the screen, as far as the amp goes check your connections. should have 12vdc on the + and the remote wire to the ground on the amp. if your good on the connections at the very least the protect light should be on. if its not then something is wrong with the amp itself. verify all connections before assuming its the amp first.
May 24, 2014 | Kenwood DDX812 Car DVD Player
When I turn my dvd player on, the volume will lower on its own to almost mute. It is hit or miss weather or not the unit will turn off on its own saying protect. All connections are good. Inside is clean....
When you've got good volume, try unplugging the speakers (only for a very short time) to see if that whining noise is still there or if it's stopped. We're trying to see if the whining is related to the low volume and "protect" or if it's only coincidental.
Try unplugging all the cables (except the power cord). Turn the player on & off several times & see if that whining noise acts the same. Also see if the player goes into "protect". What we're trying to do here is see if it NEVER goes into "protect" with the cables unplugged.
Last... try to get it to start & run without going into "protect", with all the cables unplugged (except power). Plug the cables in, one at a time, and see if plugging one of the cables in forces it into "protect". If so, there's something wrong with that cable or whatever's on the other end of that cable. Unplug it again & restart the player - no "protect"? Wait a little while, plug the cable in. "Protect"? Check the other end of that cable.
If it goes into "protect" with nothing plugged in except the power, then the player is probably a write-off, ready to be replaced (it's not very often that DVD players are worth repairing these days).
Nov 05, 2013 | Samsung HT-Z310T Theater System
No light on sony amp
Check your connections. Use a meter or a test light to make sure that the amp is getting power, ground and that the remote turn on is also switching on when the radio is on.
Jul 29, 2012 | Sony XMGTX1852 Car Amp
MY soundstream LiL Wonder 4.620 is only going in protection mode
Disconnect all speakers Meter power, remote, ground at amp, if all is good move on, if not check main fuses
Turn amp on; If in protect mode then your amp is toast Turn amp on, if not in protect mode then start reconnecting speakers one by one until your amp goes into protect mode, then you'll know which speaker is bad.
Sep 19, 2011 | Car Audio & Video
I have a kicker 500.2 red protection light is on and red light on top of amp flashes every couple seconds. Have checked all connections and other amp in truck works good. I bought two of these amps and...
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
Jul 25, 2011 | Kicker KX500.2 Car Audio Amplifier
Amp cycles on and off
Hello it sounds like the amp is going in & out of protection normally the protect light will pulse at the same time but is not always the case if you can get hold of a voltmeter set it to the 20v range & check to see if there is 12v present between the RCA (Phono socket) input & shield, if so then the switch mode power supply transformer is faulty. It could also be a number of problems elsewhere as well so really needs to be inspected by an experienced engineer.
Nov 13, 2009 | Car Audio & Video
600w legacy amp
9 times out of 10 if your amplifire is in protect mode and evrything externaly, like speakers, fuse, voltage, etc. checks out fine then
either you have shorted out output transistors or power mosfet transistors. Basicly that just about what happens with car amps.
It's easy enough to fix IF, IF you know what your doing. First you
need to check the output transistors with a digital volt meter on diode check, If they check out then check your power supply mosfet transistors. I can almost guarantee this is your problem. Very common. I buy non working amps all the time and repair them. Listen to pbabin also he has helped me out. Good luck
Sep 08, 2008 | Legacy Audio American Legacy II LA490 Car...
MA Audio HK4000D please help me ?
Turn the system off and disconnect the speakers. Turn the system on. If the amp still goes into protection mode with no speakers connected, then most likely the output transistors are bad. If the protection light is off, hook up one sub at a time until you find the one that is causing the problem
May 21, 2008 | MA Audio HK4000D Car Audio Amplifier
Amp
Sisnce you didn't mention the protection LED, I'll assume it's not on.
You need to measure the voltage across the B+ and ground terminals of the amplifier to confirm that the voltage at the terminals is least 11 volts. Also check the voltage on the remote turn-on terminal. Place the black meter lead on the ground terminal of the amp and set the meter to DC volts.
Nov 07, 2007 | Power Acoustik LT-980/2 Car Audio...
El1500 turns on but so sound
Hello fordguy, love the name i'm a ford man myself if thats why you chose it. Anyway to the amp. I buy broken amps all the time from E-bay and find which parts are bad order them and replace them and the amps work great. I just bought and recieved the same amp, Bazooka EL1500 and right away when I put power to it the protect light came on. Let me tell ya a little about car amps and the mostly the main reason they go into protect mode. First it could be something small and stupid like a fuse, sometimes amps protect light will still come on even if fuse is blown. Maybe something inside is touching something else causing it to go in to protect mode like lets say a small peice of solder is connecting to solder traces together or whatever, you get the idea. Second and this is I'd say 80% of all protect lights coming on. You either have shorted out output transistors or powersupply mosfets transistors. This is mainly the cause of this all the time. Sometimes though it's not and you have to do further testing. With your amp, I don't know what was going on at the time of when it quit. The capacitor you speak of is fine it's just the protective shrink looks melted cause thats how it was done when amp was made. You need to test all output transistors and power supply mosfets with a digital volt meter set on diode check. Let me know what you find and itf you need help just opost a comment asking for my e-mail and I will taake you thru the steps. If this helps, please rate it so I can get out of this apprentice status.
Feb 02, 2007 | Bazooka EL1500 Car Audio Amplifier
Kole audio QX1-2400D Car Audio Amplifier Logo
222 people viewed this question
Top Kole audio Car Audio & Video Experts
David Burbee
David Burbee
Hashim Khan
Hashim Khan
Terry Hair
Are you a Kole audio Car Audio and Video Expert? Answer questions, earn points and help others
