ViewSonic VA1930WM  LCD Monitor
Problem for ViewSonic VA1930WM (Black, Silver) LCD Monitor
Monitor wont work properly
By evolutiongra on Aug 05, 2009
when i turn my pc on ..the monitor turns on with no problem but most of the time it just turnes off complitely after like 5 mins... then next thing u know it turns on by itself .. on and off ... idk what should i do in this case..i though it was the plug in the back ..trying with no luck ....
Solution #1
posted on Aug 05, 2009
Not Rated)
pdsimonson
Rank: Wiz
Rating: 84%, 38 votes
It sounds like the power supply in the computer is not putting out the correct amount of juice through the motherboard, and into the monitor. either that or if you have the monitor connected to a seperate video card, than the card could by no good. Try a different monitor if you can, and see what happens. If the other monitor works good, than it is the monitor its self.
Was this helpful?
Yes
No
Popular Solutions for ViewSonic VA1930WM LCD
Questions and Unsolved Problems for ViewSonic VA1930WM LCD
Do you recommend ViewSonic VA1930WM (Black, Silver) LCD Monitor?
Answer
Answer
I have the exact same problem from this piece of **** monitor. When I called them to go thru the BS... (More)
Answer
happening as often as every 10 seconds. It will go away on its own after a few seconds. Pressing the... (More)
Answer
Was told to replace the cable and still that didn't work. Was told to do the "Memory... (More)
Answer
the screen will work fine and then after a few seconds it will have a white halo looking thing... (More)
Describe your Monitors problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
in , PA
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
