SOURCE: Hotpoint ultima 1200 Wm72 Erroe E14
I think you will find that the error relates to the heating element.
E14 on the Hotpoint WM75E means that there is a problem with the water heating.
SOURCE: erroe 17
manual said electrical / mechanical. As it's to do with the CD it's probably mechanical. not a lot you could do, Probably the motor is jammed, lens needs cleaning something like that. Best think without opening it up. shoot some air down into the CD slot
SOURCE: erro code on printer
Error code means
E27 = Waste ink absorber full or platen waste ink absorber full
Yes, you can do this yourself.
YOu can do a search on here for the error code, there are instructions on how to reset the error and clean the absorber..
Or you can do a search for the "SERVICE" manual for your printer and
order it, then follow it's instructions to clean the pads and reset the
error.
Let me know if you can't find the solution on here, and I will post it for you.
