Question about Samsung SHR-2082 8 Channel Stand Alone Dvr with Cdrw
Samsung SMO 151QN need to purchase the proper recorder for this unit
I have a samsung SMO 151QN and need to purchase the proper recorder for this unit. any suggestions?
  • Anonymous Feb 09, 2008
    same problem SMO 151 QN
  • 4 Answers
We're using a Samsung SHR-1040 recorder with
a Samsung SMO 151 QN. It has more options than
needed ( has it's own camera ports) but it's cost
effective and records well. It has been in use since
July 2007.
Posted on Jan 16, 2008
1. Connect LAN cable of Cable/ADSL modem or Direct Fixed/Static IP LAN Line to WAN port of IP Router.or hub/sw with cable/lan terminal
2. Connect LAN ports of IP Router/switch/hub(1~4 or 1~8) to Ethernet port SMO-211QN/SMO-150QN to be set up and to
Ethernet port of Local PC to use during setup.
3. Connect Video cable of Camera to MONITOR.
4. Turn on the MONITOR power.
This a basic setup local no internet static ip you will have to
follow directions for setup in the software program you install
on the computer the uset the computer. The computer connected to the lan terminal
I am just giving you the basics you are goilng to have to read
and understand the rest as far as the rest of the setup on the
computer This is from page 107 of your manual
Link to manual if you dont have it
Dec 07, 2007 | Samsung Color Indoor Security Camera with...
My samsung dvd hr753 will not tune to stations? Our region recently switched to digital so we no longer have analogue signals. Could this be the problem?
Yes this is your problem that you no longer receive an Analogue Signal.
This unit doesn't contain a Digital Freeview Tuner so you will need to purchase some sort of External Digital Freeview Box to connect to this unit to enable you to continue recording on it.
Jul 11, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
Need a manual for my samsung Servillance carmera
You can download the manual from
Sep 07, 2009 | Samsung Weather Resistant Security Camera...
Samsung DVD-SH855
Hi Thanks to all. Problem was solved by my son who suggested that I turn the unit off in standby mode. Samsung DVD-SH855 will not record via timer settings when the unit is left with pwr on. Only works if pwr switched off.
Had I known this prior to purchasing I would have purchased a brand that worked with pwr on.
Apr 30, 2008 | Televison & Video
Cannot view replay
It has something to do with the software and hardware as well.
But not the monitor that is trouble you.
Mar 30, 2008 | Computers & Internet
Samsung smo-120s
I broke a cable module on one of the original cables during installation. I tried to substitute a normal telephone cable with 6 pin RJ11 modules but it wouldn't work. I finally got the broken module to work but there is apparently some difference between the pins or wiring of the furnished smo-120S cable and RJ11 phone cable.
Sorry I don't have a solution but perhaps will help you find a solution.
Jan 22, 2008 | Televison & Video
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
Connecting the recorder to the security system
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung SHR-2082 8 Channel Stand Alone Dvr with Cdrw Logo
649 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
