Question about Maxtor OneTouch III TURBO EDITION 1000 GB Hard Drive
External hard drive not working
My computer does not recognize external Maxtor one touch III turbo edition. Is there an upgrade driver for windows XP or Vista?
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
Hi - I have a Maxtor One Touch III, 500GB drive (3-4 years old) that has backed up my last 3 computers running Windows XP. I'm now trying to connect it to my new laptop running Windows 7, when I run the...
Hi , it seems the 'error code that you are recieving, is due to a 'connection in the {USB}.
Try "Updating the Driver / Software!"
"Go to this "Website!"
Fill-in necessary information.
ie: Model #, Brand, and or Operating System...
"Select the [Drivers] you need from the "List."
View: OneTouch III EMC Vista Update:
View: OneTouch III USB
Read below:
---> "Updates software to run in Windows Vista/XP/2000"
"Download the Drivers!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Click here: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-downloads&vgnextoid=35c6069f356d3110VgnVCM100000f5ee0a0aRCRD
Mar 15, 2011 | Maxtor One Touch III 500GB FireWire/USB2.0...
My PC or Laptop will not recognize my maxtor one touch 111 120GB hard drive. it was working fine befor and now i get an error from windows that says: thre was a problem installing your new hardware
It is your driver related issue.
Check your operatign ssytem version is winxp sp2 ?
SP2 is perfact for usb 2.0
Also you can try to uninstall all usb driver and install inf update utility it is comes with motherbord disk.
You can uninstall usb drivers from computer with device manager .
For that go to my computer proeprty then hardware then device manager then uninstall all usb drivers.then restart the computer then check.
Also check your harddriver usb cable is working fine tryt all usb ports of computrer 1 by 1.
Also try in another computer.
Aug 24, 2009 | Maxtor OneTouch III Mini Edition 120GB...
My computer no longer recognizes my Maxtor One Touch III Firewire 400/USB 2.0
go to my computer proeprty then uninstall usb driver and then right clik any driver then clik on scan for hardware then it searches usb and install automatically.
May 22, 2009 | Maxtor One Touch III 500GB FireWire/USB2.0...
Maxtor One Touch III mini ext HD 120 GB
I am not sure what model you have but the Maxtor hard drive downloads site has many system drivers, original software and Vista driver updates. The site is located at:
http://www.seagate.com/www/en-us/support/installation_assistance/installation_instructions/external_drives_&_personal_servers/ot3
If that does not work contact Seagate (they own Maxtor) at 1.800.SEAGATE (1.800.732.4283).
Feb 12, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Re problem with maxtor one touch 111 Mini
Try downloading the most recent one-touch drivers for xp that are available and installing those.
Nov 03, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor OneTouch III TURBO EDITION 1000 GB Hard Drive Logo
90 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
