Question about HP Pavilion dv1000 Notebook
Wireless on switch
Hi ya
On a Fujitsu Siemens Amilo Li 1718 - where is the switch to turn on the ability to have a wireless connection??? Please if someone could help I'd be eternally grateful!
Re: Wireless on switch
Posted on Jul 27, 2009
  • 116 Answers
You must first detemine that your PC is equipped with a wireless adapter card, because even though it may look like one is installed, you may not have purchased one with the PC. It is common. Let me know I will assist you with this issue, in additon I need information like:
can you connect to the internet through a landline?
How old is your PC?
Have you every used it for wireless?
Posted on Nov 28, 2007
0 characters
3 Points
Hi! i have fujitsu siemens amilo li 1718 ms2212 .does it have mic at all?couldnt find it and skype says problem with recording device thanks
Here is a link to the Fujitsu support page for this here you can find the technical specs for this PC
Let me know if you need anything else!!!
Jun 29, 2011 | Fujitsu Siemens AMILO D-7830 Notebook
Need pci modem driver for amilo d7830 please
You can download from this link.
Or you can download acer driver that can be same because most netbooks' chip's are same as acer .
Folow the bellow link,
Product Family: Netbook
Product Line: Aspire One
Product Model: AOD250
Hope it helps ,and can reply me.
Jan 11, 2011 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu Siemens Amilo D7850, wireless internet, hi does it have
Tyr pressing Fn and f1 button or the combination or Fn and F2 it will turn the wireless ON on the laptop, then you will be able to see your router or modem's wireless connection and will be able to connect
Let me know if this will help
Dec 03, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
My wireless wont turn on Amilo Li 2727
my laptop amilo li 2727 wireless wont turn on
Oct 29, 2009 | Fujitsu Siemens AMILO Xi 1546 Notebook
Amilo 2727 wireless adapter hotkeys
Please uninstall the driver though Device Manager and get it install from the disc given by manufacture website or download the latest driver.
Path is :
My Computer(right click)->Properties ->Hardware->Network Adaptor
Jul 30, 2009 | Fujitsu Siemens AMILO Pro V7010 Notebook
I have a fujitsu amilo Li 1718 and i cant turn on the wireless conections.
"Fn" + "F2". to switch on wireless
Other solutions are:
The way i get around it is to Hibernate my laptop instead of shutting it down. This makes for a faster startup, saves all your open apps, and ,of course, keeps the wifi enabled.
Here is the solution for starting wireless on startup :
go START > run > notepad ENTER
write this in the notepad
Set WshShell = WScript.CreateObject("WScript.Shell")
Set oExec = WshShell.Exec("C:\Program Files\Launch Manager\WisWBSet.exe")
do while WshShell.AppActivate("Wireless Status Option")=False
WScript.Sleep 100
WScript.Sleep 100
and save it as wifi.vbs
put the file wifi.vbs in the startup folder and this will do the job
Hope this helps, good luck
Jul 19, 2009 | Fujitsu Siemens PC Laptops
I have a Fujitsu Siemens Amilo Li 2727. The
Try downloading the automatic driver update tool from the website.
This should normally fix this problem by updating all drivers.
Jul 09, 2009 | Fujitsu Siemens AMILO Pro V7010 Notebook
Wireless connection
You did not state which laptop model you have. Here is a list of the most common key strokes or switches:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | Fujitsu AMILO PC Laptops
Hardware switch on a amilo fujitsu laptop
On some of the Amilo Models, the Wi-Fi button is actually a key combination on the keyboard. Have a look for a key with the wireless symbol on it - looks a bit like an antenna, and hold Fn while you press that key. Your Wireless should come back on.
Fujitsu's can be odd, cause the hardware button (mentioned above) doesn't actually disable the driver in Windows, just turns it off so no connections appear.
Mar 05, 2009 | PC Laptops
HP Pavilion dv1000 Notebook Logo
858 people viewed this question
Top HP PC Laptops Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a HP PC Laptop Expert? Answer questions, earn points and help others
