Question about Microsoft Xbox 360 Console
Replacing cables I have the sound but no video problem..... Is there really a chance that replacing the cables would actually work?
    Problem Solver:
  • 18 Answers
Yeah could be your av cable if not it will most likely be your av socket if its the socket you will have to send it in to be repaired
hope this helps
Grant
Posted on Nov 26, 2007
The audio pin cable won't stay in the receiver
Chances are there cable is no damage not the cable but the actual port on the TV try to use a different input for sound because I'm sure your Port is now damaged in the TV chances are your TV supports another audio input besides the one you're using
Mar 18, 2018 | Televison & Video
HDMI cable but sound does not work
Do you have all of the AV jacks plugged in? If not, Plug all of them in. If you only have room for two of them, Plug in the yellow one, and the white one. For video games, Plug in the yellow one, and the red one. How old is the TV? Chances are, if the TV is really old, the sound might not work. Or you could try someone who works with TV's. :-)
Nov 15, 2015 | Televison & Video
My samsung hl-t6187s has no red
More than likely your red led is bad I have this model and I have had to replace it twice in the last four years the part is available online and is fairly easy and quick to replace if you are handy with a screwdriver the actual procedure is available in a video on YouTube for replacing it.
Apr 18, 2014 | Samsung HL-T6187S Television
How do I troubleshoot a problem with no video? Games nor movies play. I hear the disc spinning up, but the video never displays. nor does the sound for that matter, but I assume that is due to the disc no...
Even if it was a bad disc you should boot up to the home menu without problem. I would try replacing whatever type of AV cable you have running from your PS3 to your television. It could be once solid black cable with USB like ports on both ends (HDMI) or a cord with one end split into various colors (AV or Component) If replacing this cord doesn't help you may have a bad connection on one or multiple ports on your system/tv or it could be an internal problem.
Feb 24, 2011 | Sony Playstation 3 (PS3) Console
I have aony receiver STR AV-880 serial # 803492 left side speaker snowy sound on A and B setting help please
Chances are really good that you need to replace the speaker relay for that side. I recommend replacing all speaker relays. The contacts are dirty. You can get parts from Sony. You will need the relay part number off the top of the relay to order from Digikey or similar parts places. You can try cleaning the relay contacts with a contact cleaner. Sometimes it works.
Apr 21, 2010 | Audio Players & Recorders
Xbox 360 Video Problem
HI. Replacing the video cable would also be my first suggestion. The Xbox AV cable has many manufacturing faults. If you are using the original cable tat came with the unit, I suggest to replace it with newer model.
Now, if you experience the same issues after replacing the original AV cable, this will lead to a more serious issue that concerns the HANA chip. This chip is responsible for the transfer of information through the AV cables. The transfer port(the AV cable end that is inserted into the Xbox), is directly connected to this actual chip. If the internal connections to this chip have failed, or are failing, this will be the culprit. The chip will need to be replaced, or the solder joint will need to be resolderd. If this unit is still under warranty, I would suggest to contact Microsoft for a free repair ticket. Do Not open the case if the unit is still under the manufactures warranty. This action will void the warranty.
NOTE_ Try replacing the AV cable first.
Jan 19, 2010 | Microsoft Xbox 360 Console
No sound from any source
ICheck first the video cable at the back of receiver.
If that does n ot work , then unplug power cord and all cables , wait ten minutes and plug back.
Try replacing the cables at the back.
Try using a different type of connection cable.
If still no luck, then the unit can be faulty.
May 28, 2009 | Pioneer VSX-D912 Receiver
NO SOUND,VIDEO IS FINE
hmmm, this may be either really tricky or simple as pie. If the Video is coming through but sound isn't the first thing I think of I bad RCA wires that come from the console to the TV (the white and red, yellow is Video) Any chance you have a "back-up" cable to try out?
Apr 24, 2009 | Microsoft Xbox 360 Console
No Picture on TV
Try replacing the A/V cable. It sounds like that the cable that is for the video is broken. I would replace that first.
Mar 16, 2009 | Nintendo Wii Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
