Question about Emerson Televison & Video
How can I connect my ZV427EM5 to a TV using optic fiber connection? to access start up menu?
Go into settings and activate it in audio
pattersj78
  • 70 Answers
SOURCE: No sound when connecting with a fiber optic.
have you tried a new cable?
Posted on Oct 27, 2007
simplemitch
  • 752 Answers
SOURCE: Need fiber optic input jack for Onkyo TX-DS575
Had it ever worked, or are you setting it up for the first time?
Have you ASSIGNED the digital input in the menu?
Posted on Dec 18, 2007
Turk_97
  • 138 Answers
SOURCE: Unable to access digital audio output options
Well you also need to have a digital feed to the television. example: When I run my optical cable from my dvd player to my television directly. I went in to my menu options on my source and enabled this. If you are wanting to run this feed to your a/v amp? You may want to run the original feed from your dvd player to your amplifier directly, you will get a sound quality that is far superior to what you seem to be doing here.
Posted on Sep 24, 2009
JollyRoger00
  • 59 Answers
SOURCE: Digital Audio Output Problem
connect the optical line from the DTV box to the audio system directly.
mlapres
  • 757 Answers
SOURCE: Got a Kenwood vr405 surround receiver, a Sanyo
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Posted on Jan 14, 2010
Testimonial: "Thank you for the insight. I may have figured this out on my own eventually but this definitely got me situated much much faster. "
What must I do to connect a sound bar to my tv ?
Before you buy a sound bar look on the back of your TV to see if there is a digital port and /or a fiber optic port. The fiber port may have a cover on it so the red laser won't cause eye damage. If your TV is so equipped, then get a sound bar with a fiber optic connection. Not many older TV's , flat screen or nor have blue tooth capability. Unless you know for sure your TV does, don't expect the sound bar to have it too.
Nov 09, 2015 | Insignia Televison & Video
How to connect the PTH, SDH, OLT AND ONU?
The current technology in PTN direction development, Huawei PTN packet switching network, SDH (synchronous digital system), the ONU is PON (passive optical network) in the concept, the ONU is lower.Access layer is commonly by hosting online travels.OLT, ONU is through the PTN, Ethernet, etc., belongs to the category of the access layer, and should be OLT, mainly VOIP access, with your said, the concept of SDH transmission, so OLT, are all belong to the category of transmission bearing networkThe current technology in PTN direction development, PTNPTN () packet switching network, SDH (synchronous digital system), the ONU is PON (passive optical network) in the concept, the ONU is lower.Access layer is commonly by hosting online travels.Huawei OLT, ONU is through the PTN, Ethernet, etc., belongs to the category of the access layer, and should be OLT, mainly VOIP access, with your said, the concept of SDH transmission, so OLT, are all belong to the category of transmission bearing network
Nov 09, 2015 | Cell Phones
Want to connect fiber optic audio cable
If you have something providing an optical signal, you will need something such as a receiver that will accept and decode the optical signal. If you are able to make use of the HDMI instead of the optical audio channel, this would be the easiest bet. Otherwise you are looking at needing to get a receiver if you want to have more than 10W of stereo output, or if you simply wish to convert the optical signal into something the TV can understand, any fiber optic to analog converter, such as Amazon item B003OND0N4 (Search that string on Amazon)
Mar 28, 2014 | Emerson LC320EM9 32 in. LCD HDTV
HI, i have a white screen on this tv. it,s out of warranty being about 3 years old , one day it suddenly went white completely . opened it up to replace the inverter board , but did not cure it . when i...
No.This tv problem it is not a grounding earth problems.It is a loose connections Fiber Optic cables pins connections contact problems on that board some where,on those Fiber Optic cables on that board those pins connections are not made tightly between them on that area on that board,where it is loose,some where u put pressure on it inwards.Why don't u take all the Fiber Optic cables aparts and take long noise plier bents all the connections pins a little bit.Than re connections all the Fiber Optic cables again on that area should solve this problems.
Sep 22, 2011 | Sony KDF-E55A20 55 in. LCD Television
Can i connect a pc to a wii to view pc screens a my tv
Instructions things you'll need:
  • Wireless router
    • 1 Determine if your Internet connection is compatible with the Wii's online console features. If you are using a dial-up connection you will not be able to connect to the Internet through the Wii console. The best connectivity is with a cable, DSL or fiber-optic connection.
    • 2 Start up your Wii. Go to the main menu. Click on the Wii icon button on the bottom left side of the screen.
    • 3 Select the "Wii Settings" button with a wrench icon. Go to the "Wii System Settings" menu.
    • 4 Click on the arrow on the right side of the screen to scroll to page two of the settings. Click on the "Internet" tab.
    • 5 Select "Connection Settings" from the menu that appears. Your screen should show three connection slots all saying "none" next to them. Select "Connection 1."
    • 6 Choose "Wireless Connection" from the pop-up screen. A new screen will appear that reads "Search for an Access Point," "Nintendo Wi-Fi USB Connector," and "Manual Setup." The easiest way to set up the Wii online is to select "Search for an Access Point."
    • 7 Wait a moment for your Wii to find an access point. When the words "Choose the access point you want to connect to" appear on your screen, click "OK."
    • 8 Pick your access point. Choose the point that is listed with a green signal strength icon.
    • 9 Save the settings by clicking "OK." Your Wii console will perform a test. A window will pop up asking you to perform a Wii system update.
    • 10 Complete the system update. Read and agree to the "User Agreements." You should be able to view movies, TV shows, websites, news and games from your PC on your TV.
Apr 17, 2011 | Nintendo Wii Console
Not getting sound thru speakers only tv with hdmi cable connected do I need to connect Digital fiber optic cable too Also able to download owners manual for vsx1017txv
Receivers of this complexity require some patience. I believe the HDMI on this receiver is only for on screen display and video pass through. The audio needs to be separately connected. For digital audio you need to connect either via the digital audio coax or fiber optic input. I replaced my entire 1980s audio system with this unit and have been very happy. It's compact, and I feed it everything via a 35' fiber optic cable (under $20!) tied to a 3-way passive fiber switch (under $10) connected to my computer, a Tivo, and a DVD player. Sounds amazing (make sure to run set up to get the unit to perform with all of your speakers! -- I use an 8 speaker 7.1 surround set up).
Jun 17, 2010 | Pioneer VSX-1017TXV-K - iPod Ready, XM...
Connecting fiber optic cable with ''SC'' type connectors
No it should clip in, however you have the wrong connector on the end, usually these cables come adapters with them to suit you source or TV.
Get your self another cable with adapters, try eBay...!
Thanks
Oct 09, 2009 | Televison & Video
I cant hook my PS3 to the surround system for Sony DAV-HDX275W
what exactly is the problem? no connections? or connected and cannot get it to work?
Aug 31, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
LG LFD790 installed with cable
if there is an input on the back of your cable reciever get a fiber optics cable and put it in to your theater system and into the box then select "ez/optical" and your tv should come through, or you can connect the fiber optics cable on the back of your tv into the system and keep the tv volume off
Dec 25, 2007 | LG LFD790 System
Televison & Video Logo
20 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
