Watches Logo
Robert Lowe Posted on Feb 19, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Timex Expedition Indigo watch stopped glowing. It is only 1 year old but I replaced the battery thinking the battery is bad. It did not help What's up?
Stephen Miller
Level 3:
  • Timex Master 1,645 Answers
  • Posted on Feb 19, 2019
Stephen Miller
Timex Master
Level 3:
Answers
1645
Questions
0
Helped
864537
Points
9471
5 Related Answers
Anonymous
  • Posted on Sep 28, 2007
SOURCE: watch battery replacement
I have a Timex Expedition Indigo with a metal case. Not sure of the exact model number but on the back there an M6 below Expedition. Anyway, I had the same problem of snapping the back back on. I found a "battery" website that had some suggestions that should be typical of any snap back case watch. http://www.online-batteries.co.uk/whichbattery.shtml specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment. The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even. Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it. Good Luck, Richard
Anonymous
  • Posted on Jul 06, 2008
SOURCE: Replaced battery, now no beep.
I have a Timex Digital Heart Rate Monitor 585 (product code T5C351F5)m, which has the same Short AC Pad and battery +ve message. There is an arrowhead pointing to the pad. It's a raised metal platform - a bit different to some of the Ironman's mentioned above. Here is a pic...6e1fe0e.jpg
Anonymous
  • Posted on Jun 17, 2009
SOURCE: How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
Anonymous
  • 183 Answers
  • Posted on Sep 21, 2009
SOURCE: Timex Expedition E-Instruments E-Compass Watch
Timex makes its manuals available for download from their website:)
http://www.timex.com/gp/node/n/255235011/178-9815641-8595102?ie=UTF8&timexBrand=core
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 26, 2010
SOURCE: How to set the alarm for the Timex Expedition
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, plz.
Timex Expedition with Hydra Timer started randomly changing time and functions. Battery was replaced 1 year ago.
Either a loose connection inside or it just needs a new battery. They can be power hungry depending on how you use it and what battery technology type was used in the last one.
How Long Do Timex Watches Last? (Watch & Battery Life)
watchesoftoday.com https://watchesoftoday.com > Blog
A Timex watch battery will last between two and five years, depending on how often you use the Indiglo feature, while the watch itself can easily last five to ...
What size replacement band
There are several different Timex Expedition models. It's best to go to Amazon and search to find your model. Their product page should show what is the replacement band size. It may be 18mm, 19mm, or 20mm.
3answers
Indigo light doesn't work
It is possible that either that the movement of the watch is not aligned properly after a battery replacement.
My Timex Expedition Indiglo wrist watch has had two new batteries and keeps on stopping quite frequently. The Jewler cleaned everything and it still won't work properly. Is there somewhere that I can send...
The watch would have to go back to the manufacture, try www.timex.com for customer support and ask for technical assistance, they should be able to direct you to the nearest authorized store or they may have you send it to them.
3helpful
Just purchased timex 1440sport watch with heart rate monitor strap and there is no date/time, etc. showing on screen and indigo lite does not glow. Battery dead or watch needs to be activated??
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.If you can not sort the problem after following instructions, you may need to replace battery. Rate me, please
2answers
Timex 1854 chrono,indigo lght not working. 2nd one in 4 mths?
the same problem, after 3 years of use.
Night Indiglo light was very bad.
thought the battery replaced it, the battery was okay.
began to collect but probably need a special tool, the glass cracked)
1helpful
1helpful
Indigo light is not working properly, battery needed?
Timex suggests that you have a watch repair person change your watch batteries. I think it would be a good idea to try and replace the battery, but if that fails to work, contact Timex for advice. If they suggest that you should replace the entire wath, keep the battery. I have no guarantee that any of that would work, though.
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
