indoor unit operation and timerlights blink 4 times,pauses then timer light blinks 3 times/after reseting normally runs about 5 minutes but sometimes may run all day/any suggestion?
The wall unit won't respond to the hand held timer/control. Worked fine a month ago. Batteries...
(More)
The wall unit won't respond to the hand held timer/control. Worked fine a month ago. Batteries seem OK in hand held unit.
Timer and operation light flash similtaniously 5 times then 5 second gap then flash again. continues...
(More)
Timer and operation light flash similtaniously 5 times then 5 second gap then flash again. continues when turned off by remote but no heat. Manual says "immediately stop operation and consult authorised service personnel". Did this, they unsure and say turn off at isolating switch for one and a half hours then try again. Third try this has worked but did it again and again two tries before starting, going okay presently. Any ideas what this code is advising?
evap is blinking two green light flash and condensor will not operate on my fujitsu aou30clx split...
(More)
evap is blinking two green light flash and condensor will not operate on my fujitsu aou30clx split ac unit
