I’ve error code e7:02 on my washing machine what is mean , where is it in the machine and what do I replace
  • Washing Mach... Master
  • 5,800 Answers
The Fisher-Paykel washer e7:02 error means that the motor reported the loss of one phase at the control unit. You'll need to check the resistance across the wiring and the motor to determine the where the fault is. Unplug the washer and check the wiring harness, connectors and the motor.
I'll assume that the expected resistance doesn't change between most models. The resistance at P171 of the motor control module should be 28 Ohms. The resistance at each winding in the rotor and stator should be 14 Ohms. Replace any faulty part. If the resistances and wiring are fine, then the motor control module has to be replaced. These resistances are from the service manual for the WH8560J1 which is available at ManualsLib: https://www.manualslib.com/manual/1264071/Fisher-And-Paykel-Wh8560j1.html#manual .
Please add a comment with the model of your washer if you'd like me to find a parts list or diagram. If your washer is under warranty or you do not feel comfortable checking the wiring, contact Fisher & Paykel for service.
I hope this helps.
Posted on Feb 19, 2019
  • 4 Answers
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Posted on Jul 08, 2008
  • 34 Answers
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Posted on Aug 13, 2009
  • 6 Answers
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
Posted on Sep 09, 2009
  • 174 Answers
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
Posted on Jul 16, 2010
richroth
  • 9472 Answers
SOURCE: My washing machine keeps displaying error code F17 and won't go on. Does anyone know what this means and what I can do to fix it?
F17 indicates no water coming into the condensing chamber during drying.
Unplug the appliance.
Take the top off.
Check to see if the condensing chamber below the heating chamber is blocked.
Posted on Oct 16, 2012
Will not fill with water & reads error code ddr! What does that mean? why won't it fill with water?
DDR means the door latch is loose or bad. There is a switch inside that needs to be checked or replaced.
Oct 16, 2015 | Washing Machines
Tip
Hotpoint Washing Machine Error Codes or Fault Codes
If you are having a problem with your Hotpoint washing machine it is helpful to know what the error code means. Some of the problem are very simple to fix and do not require a service call to remedy the problem. Here is a list of error codes and the meanings for Hotpoint washing machines
If your error code has an E in front of the number and not an F as shown here, the meaning of the code is still the same
# F10 - This means there is no cold water coming into your washing machine You should check and make sure that the valves are on and that the hoses are not kinked.
# F11 - This means there is no hot water coming into the washer. Again make sure that the valves are on and that the hoses are not kinked anywhere. Also hot water will freeze before the cold water does, if it is very cold where you washer is, check for frozen pipes.
# F12 – This code means that the water is not filling when calling for mixed temperature water. Again, check the hoses and valves.
# F13 – If you have water supply problems this code could also display. Check all hoses and valves.
# F14 - A If this code comes up you have a problem with the washer water heating system. It is usually best to get a professional to repair this problem.
# F15 – The water is not being drained from the washing machine properly. Check the discharge hose to make sure that it is not blocked and that it rises to the minimum height requirement for your washer.
# F16 – The water level is or has been too high in the washing machine. The water inlet valve is probably not closing properly. Turn off the water at the hot and cold water valves and replace the water inlet valve.
# F17 - Door is not closing properly. Firmly push the door closed, and the washing machine should work. If you cannot get the machine to run by slamming the door, then you will need to have the door switch repaired or replace it your self.
# F20/1 – This means that you have a problem with the thermistor that senses the water temperature in your washing machine. It will need to be replaced. This error also could occur if the temperature where the washing machine is, is below freezing.
# F30/31 – This means that there is a problem with the washing machine motor. Check that you do not have too much in the washing machine. There also could be a communication problem to the motor. Unplug the washing machine to reset it and then try to run a cycle again.
# F40 - Water is below the minimum level for the heater to be working. You need to find out why there is not enough water entering the washing machine.
# F41 – There is a problem with the water level detection system.
# F50/51 – This means that the washing machine has lost its programming. The washer will run in a default mode till you can get it reprogrammed.
on Mar 16, 2010 | Washing Machines
What does the error code "OP" mean?
OP - Open Thermistor - Replace thermistor.
Aug 27, 2013 | Washing Machines
LG washing machine loud and error code LE
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
heatman101
Jul 02, 2011 | LG WM2301HW Front Load Washer
Hitachi washing machine error code Fb indicates problems. what prolems is that? Can you list out the meaning ot each error code.
My washing machineSF-110SS
have a display FD. Anybody know what's that means? And how to solve it. Please
Jun 23, 2011 | Washing Machines
Machine reading F63
I hope a way to delete this code from the screen
I waited for 20 minutes and stopped flashing screen
Will not disappear
Press any buttons after the screen has stopped flashing
Jun 20, 2011 | Washing Machines
What does error code f67 on a siemens wash machine mean?
I have a Siemens WM16S772DN washing machine and encountered the error code "F:67" followed by repeated beeps. (Note: Siemens and Bosch are related companies). I called Siemens and they said the code means "Fatal error" or program error. The service technician was called, and he replaced the electronic board and reprogrammed it.
Apr 18, 2011 | Bosch Washing Machines
Our Neptune Washer won't start up. It shows a Code (ol). What does this mean? We;ve tried unplugging & and Re-loading it. Still OL code.
From the FAV6800A/FAV9800A Service Manual page 14 that error code = oL Machine Paused-Load Wedging
Google this "16022808 Revision 0 December 2003" to find the Service Manual if you are going to DIY the fix.
Mar 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
Lg washer dryer wd12126rd what does ve symbol flashing mean.
Actually it is UE error.It means UNBALANCE error where either the machine is not LEVEL or wash inside is on one side.
Check.
ALPER
Cyprus
Aug 05, 2010 | LG WD-12126RD Front Load Washer / Dryer
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
